06-08-2009, 10:47 AM | #46 | ||
Re: Parts list/application/source
WOODY - All the rear end stuff came from Coleman Racing Products 800-221-1851. You have the (wide 5) hub set up. You should also order the axle washer. You set these up just like front wheel bearings. You may also want to order the special socket adaptor to tighten the axle nut. makes setting the bearing up easier. I'm at the office and don't have the coleman catalog here or I'd get you the part #'s. Let me know if you run into problems... Bruce |
06-23-2010, 04:36 PM | #47 | |
I need to know where to purchase the pins that hold the rear brake pads in place and the part number. I don't want to use these pins to many times. Thanks
Jim Woodruff Akron, Ohio |
06-23-2010, 05:42 PM | #48 | |
Kel M Panoz GTRA #17 New Zealand |
06-23-2010, 06:58 PM | #49 | |
Jim, you could call PAD or try these guys in Mooresville, NC. Supposedly they are the distributor for North America. VERY helpful - especially Dennis in Technical Support.
http://www.prosystembrakes.com/
Jim McGovern ~ Building 289 Lemans Replica ~ '92 Mustang Coupe: 347ci / Carb Pictures |
06-23-2010, 08:07 PM | #50 | |
Just purchased Fox body Mustang mounts for my GTS 351 car. They match the mounts I took out of the car during an engine rebuild. I purchased Energy Suspension 1122-R mounts.
06-24-2010, 06:32 AM | #51 | |
06-29-2010, 03:24 PM | #52 | ||
Here is the information on the rear calipers for our WC cars Brembo Part number 20.7784.31 left 20.7784.41 right Drive pin part number two required for each caliper Brembo# 20.5116.40 Pad has the parts the pin are $3.20 each
