Go Back   Automotive Forums .com Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 04-07-2012, 03:37 AM   #1
epowers777
98 trooper 3.5 Knock while reving comes and goes
Just bought a Isuzu Trooper 98 with 158000 looked clean idle good had a very slight tap didnt worry about it because it needed an oil change. On the way home enginge started knocking. I got home changed the oil. It idles perfect very quiet then when you rev it it knocks at lower rpm then sounds normal. It sounds like one cylinder. The check engine light came on. i pulled the battery checked all the spark plugs cleaned and re gapped ther ngk they do need replaced. staarted the engine which started faster than normal and it purs like a kitten tell you rev the engine and one cylinder knocks. did a test drive. it only knocks under light throttle.
Any help would be appreciated i bought this for my wife who is do any moment with our second baby cause im having issues smogging my diesel well i got screwed.
epowers777 is offline   Reply With Quote
Old 04-12-2012, 11:30 PM   #2
boritz
boritz's Avatar
Re: 98 trooper 3.5 Knock while reving comes and goes
Could be a weak timing belt hydraulic tensioner.
Is there any record that the belt, pulleys, tensioner and water pump have been replaced (routine items @ 100K miles)?
You'll find lots of Trooper info and support on http://forum.planetisuzoo.com/
boritz is offline   Reply With Quote
2005 3.5 engine rev while shift mr.daverino Altima 0 03-21-2010 09:28 PM
Occasional miss, comes and goes 94 3.8 mikmic2 Silhouette 3 07-30-2007 02:21 PM
2000 Trooper 3.5 v6 Tranny Shuddering 00trooper Trooper | SLX | Bighorn | Wizard 6 06-04-2006 12:14 PM
ABS light 01 Trooper 3.5 medic1839 Trooper | SLX | Bighorn | Wizard 1 04-21-2006 03:41 AM
Overdrive light and no 4th gear -- comes and goes tfvesquire Probe 10 04-11-2006 09:38 AM
