Old 12-05-2007, 08:35 AM   #16
kevinthenerd
Re: Acetylene as a fuel
I think I found my error. While acetylene has a positive enthalpy of formation, it produces less CO2 and H2O, resulting in less heat on the product side of the reaction.
(By the way, it's been a couple of years since I took chemistry. I just got to thinking how hot welding gas gets. I think it has to do with the fact that the output heat doesn't have a whole lot of mass to heat up, resulting in a high temperature.)
kevinthenerd is offline   Reply With Quote
Old 12-05-2007, 05:27 PM   #17
KiwiBacon
Oxy-Acetylene produces high temps because of the pure oxygen you feed it. It means the 80% nitrogen that's usually along for the ride and taking home heat isn't involved.
KiwiBacon is offline   Reply With Quote
Old 12-09-2007, 06:18 PM   #18
kevinthenerd
I didn't spell it out, but that's it... less product mass per unit of heat
dH=m*Cp*dT
Old 12-09-2007, 10:28 PM   #19
KiwiBacon
dH=m*Cp*dT
I thought you were referring to an open flame not having to heat the mass of an internal combustion engine, thus producing a hotter flame than engine exhaust.
Which was of course correct, even if that wasn't your intent.
Old 03-24-2011, 08:38 PM   #20
salesmantony
Given the extremely unstable and explosive nature of acetylene, I cannot think of any way one could safely use it. It's explosive at pressure over 26psi, it's violently explosive at virtually any mixture with oxygen or air. It can only be transported dissolved in acetone. Scary to think of someone trying to introduce it into an engine.
salesmantony is offline   Reply With Quote
Old 06-16-2022, 05:32 PM   #21
FR9
What if you used a water injector and methanol like these guys do with real high boost pressures
FR9 is offline   Reply With Quote
Old 06-16-2022, 05:33 PM   #22
FR9
I know people are using it. I just don’t know how. That’s the key
Old 06-17-2022, 08:55 AM   #23
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
That might be a record, reviving a thread more than 11 years since last post!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
