Go Back   Automotive Forums .com Car Chat > Ford > Bronco
Old 01-20-2012, 01:17 AM   #1
Andy1416
I have 2 questions about my 1989 Ford Bronco II...
To start off my truck is a 1989 Ford Bronco II XL 2.9L V6 Automatic
1st) When my engine gets warm it feels like it's shifting up then shifting down, what could be the problem?
2nd) My gas gauge always reads full until it starts getting closer to empty then it starts going down slowly, like it normally should, what could be the problem here?
Andy1416 is offline   Reply With Quote
Old 01-24-2012, 08:25 PM   #2
Bullitt94
Bullitt94's Avatar
Re: I have 2 questions about my 1989 Ford Bronco II...
1.) First thing's first - check the level and condition of your tranny fluid.
2.) Your sending unit could be getting worn out or your float could be hanging up.
If you don't already own a Ford, get one!
1994 Ford Mustang GT
1990 Ford Bronco II
2001 Lincoln LS V8
1970 Ford Bronco
2006 Harley Davidson Sportster Custom
Bullitt94 is offline   Reply With Quote
Old 10-20-2016, 10:57 AM   #3
rbethell
If you are experience hard transmission shifts, it is possible that the only problem is a low transmission fluid level. Low transmission fluid level can change the operating pressures of the transmission as well as reduce the amount of lubricant present between the clutches and bands and raise transmission temperatures. All these things can cause hard or jerky shifting. You need to identify why the transmission has a low fluid level and refill it as soon as possible.
rbethell is offline   Reply With Quote
Old 07-29-2018, 04:58 PM   #4
WILL_117
I just joined as a member and can't seem to figure out how to make a new post but I just bought a 1988 Bronco II. Drove it home yesterday, ran rough from sitting and had gage problems to include the temp gauge showing it was over heating.
Today, I decided to start some routine maintenance including putting a new thermostat in it and changing the spark plugs and wires. Though I didn't verify the gap with a gage I compared old to new and gap appeared fine, now the vehicle doesn't start. I rechecked all spark plug wires for fit, location on distributor etc. and still no start, like it's not getting fuel or not firing correct. The old plugs also appeared to be dry but as I said the vehicle had started both yesterday and this morning.
I'm guessing it's something simple but not sure what? Any help would be appreciated.
WILL_117 is offline   Reply With Quote
Old 07-29-2018, 07:29 PM   #5
aleekat
If that's all you did, either gap is wrong or plug wires are not in the correct firing order. ie you can't gap plugs by sight...What engine?
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Weird Idiling Issue With My 1989 Ford Bronco II, Please Help... Andy1416 Bronco 0 12-09-2011 10:08 PM
Hey Everyone I Have A 1989 Ford Bronco II 2.9L V6, And I Have A Weird Issues With It... Andy1416 Bronco 1 10-24-2011 07:47 PM
1989 Ford Bronco II 2.9L V6 Transmission Fluid Andy1416 Bronco 1 05-24-2011 10:13 AM
84 Ford Bronco II fuel pump access BostonKev General Discussion 1 12-18-2005 05:08 PM
88 Ford Bronco II Clicking noise killahj420 Bronco 1 03-14-2005 03:37 PM
