Go Back   Automotive Forums .com Car Chat > Toyota > LS400/LS430/Celsior
Old 06-06-2007, 03:40 PM   #1
RSauto
1991 Lexus LS400 powersteering & rack&pin
I have a question. Powersteering didn't work, we replaced the pump(didn't work), we replaced the rack&pinion(still didn't work). Any suggestions? Thanks 2 anyone who can solve this riddle
RSauto is offline   Reply With Quote
Old 08-14-2007, 09:46 AM   #2
vgb14
Re: 1991 Lexus LS400 powersteering & rack&pin
Perhaps you're fluid lines are blocked. There is a screen on the solenoid that attaches to the rack and pinion - if they took the solenoid from the old rack and reused it on the new one, it's possible it was not cleaned first. There is also a screen in the pump reservoir which has a tendency to get blocked. Often, when the pump is replaced, the reservoir from the old pump is reused. It's also possible you're replacement pump is bad.
vgb14 is offline   Reply With Quote
Old 02-03-2009, 03:53 AM   #3
pgioffre
VGB 14 has come correct.
Unauthorized ad links removed by Moderator
pgioffre is offline   Reply With Quote
