Go Back   Automotive Forums .com Car Chat > Geo > Tracker
Old 03-29-2005, 10:56 AM   #1
BMXMom
looking for panel clip
The rear tailgate wouldn't open so I took off the panel and fixed the problem. Handle and lock mechanism needed oiled.......
My new problem....trying to find the right size nylon push rivets/retainers for the panel. We have a 1991 Tracker. The local auto prts store has ordered in two different types......must be like Goldilocks because they just aren't right yet.
Anyone know where to find these? I'm waiting on a reply from an online company too.
Thanks,
Kelly
BMXMom is offline   Reply With Quote
Old 03-29-2005, 11:14 AM   #2
1995 geo tracker
1995 geo tracker's Avatar
check the junkyards or hit up the chevy dealer ,they should still be able to get them
1995 geo tracker is offline   Reply With Quote
Old 03-29-2005, 04:17 PM   #3
BMXMom
Re: looking for panel clip
I know the junkyard wouldn't be an option since they are a one-time use, but I might have to try the dealership.
Thanks!
Thanks,
Kelly
Old 03-29-2005, 07:39 PM   #4
SeanMurphy
SeanMurphy's Avatar
They're not one time use.. you push the pin in and they pop out, then you pull the pin out, insert the clip in the hole, then push the pin in the hole to reset them in place.
02 Chevrolet Tracker 4WD
SeanMurphy is offline   Reply With Quote
Old 03-29-2005, 11:20 PM   #5
BMXMom
Re: Re: looking for panel clip
Not the one's I removed. Maybe's it's because the plastic is old and that is why they broke. Even some of the new one's I purchased at O'Reilly's were not reuseable.
I'll have to call the dealership.
Thanks again!
Thanks!
Old 04-09-2005, 11:11 AM   #6
cymbidium6
Thanks,
Kelly
Got the same problem. Don't even bother with plastic replacements. Buy a dozen toggle screws from Home Depot. You know, the things they hang pictures with, the ones with the spring loaded arms that pop out? Add a dozen finishing washers and you're back in business. cymbidium6
cymbidium6 is offline   Reply With Quote
Old 03-18-2009, 05:04 AM   #7
suvtracker
These are same clips used for snowmoblie windsheilds. At least they were in my 1999 & 2000 Polaris
suvtracker is offline   Reply With Quote
