| Latest | 0 Rplys |
12-03-2010, 06:26 AM | #136 | |
SHO No Mo
Re: codes P0171, P0174 Lincoln LS V6"
Welcome to the forum! The files should be in your inbox.
-Rod |
12-09-2010, 08:09 AM | #137 | |
Can you email me the thing too so I can replace the pcv elbow. I've jut been driving like this nonstop since july..
And everytime I turn my steering wheel the engine seems to calm down for like 3 seconds and then begins pounding again. |
01-11-2011, 11:17 AM | #138 | |
Rod,
I have been having the same codes and problems with my 2000 LS i have a 3.9 v8. I have changed several coils and considiring changing o2 sensors and cadillac converter. Judging from the many post i am suffering from the same isse pcv valve and elbow prob. needs replacing. Can u please email me those pics so that i will know what im up against? |
01-11-2011, 01:22 PM | #139 | |
SHO No Mo
You won't be experiencing the PCV problems since the V8 does not have a PCV elbow. The catalytic converter also will not cause these diagnostic codes, you need to be looking for air entering the system after the MAF sensor. Since you get codes for both banks, chances are the vacuum leak is in the intake somewhere that would effect both banks.
Please confirm that you are getting both P0171 and P0174. -Rod |
01-11-2011, 03:48 PM | #140 | |
If there's a misfire , it will throw a DTC!
The ''Rattle'', you might have a bad secondary cam chain Tensioner. |
01-12-2011, 08:45 PM | #141 | |
Rod,
New member with the same P0171 and P0174 codes on an 02 LS. Would you please send your pdf files to me at danr@mac.com. Can you reccommend a good service manual and where to purchase it for my 02 Lincoln LS. Thank you for your time. Dan |
01-12-2011, 10:06 PM | #142 | |
SHO No Mo
The file is on its way. As for a service manual, you can order the factory service manual from Helm Inc. or subscribe to AlldataDIY.com for your vehicle. The Alldata information is the same as the factory service manual but a lot more reasonably priced unless you plan to own your car for about 15 years.
-Rod |
01-22-2011, 10:27 AM | #143 | |
I know this thread is old, But im hoping to see how some other people handled this problem So I would like to see those PDF files that you have Shorod on replacing the PCV valve Elbow im on my way outside to tear off the upper intake I have removing the uppwer intake down to a 20 minute job just from replacing coils and plugs so< im not to worried about it.. But I am intrested in seeing your PDF files...
My Email Is Saleen114@comcast.net And thank you in advance if you still have these I know this was an old thread |
01-22-2011, 03:33 PM | #144 | |
1) Put a tourniqute on the Inake port were the pcv crankcase tube is connected to the intake.
2) Remove old rubber crankcase tube. 3) Use a new rubber crankcase tube with an external PCV filter, you can buy both at any local Auto Parts store. $40 for a rubber crankcase PCV tube! How much doe's Lincoln LS charge for this service? Last edited by danielsatur; 01-23-2011 at 02:27 PM. |
01-23-2011, 01:01 AM | #145 | |
SHO No Mo
I don't understand your suggestion. The PCV elbow is buried enough that you're not going to get it off and definitely won't get hoses connected to it without taking off the upper and lower intakes. By the time you get that far, installing the $25 part isn't too bad. The space is pretty tight so you'd need to use two elbows to remotely install a filter on the PCV system and it seems you'd just be adding more rubber pieces that can deteriorate and cause issues.
-Rod |
01-23-2011, 02:25 PM | #146 | |
Once you remove the Intake, you can put a tourniquet on the pcv port of Intake, so unmetered air won't leak, causing lean codes.
There's no PCV oil breaking down the rubber going to the Intake, it's just Intake Air. |
01-23-2011, 03:22 PM | #147 | ||
Air enters the crankcase via a hose connection in front of the throttle. Some blow-by is added to it. The air is sucked out of the crankcase via the hose with the PCV valve that we are talking about. This goes into the intake, but it is not clean intake air. It is air with blow-by and oil vapors in it. |
01-23-2011, 04:49 PM | #148 | |
Not if there's air leaking through a bad crankcase tube.
It's nothing unusual for old school, race cars, Auto technicians to go with an external PCV filter system. Who wants to contaminate your Intake with PCV emission, Last edited by danielsatur; 02-18-2011 at 10:48 AM. |
02-17-2011, 02:07 AM | #149 | |
hi can i get some of those famouse files haha thanls for your time
02-17-2011, 07:10 AM | #150 | |
SHO No Mo
Should be in your inbox.
-Rod |
