05-07-2007, 02:02 AM | #1 | |
1994 Mazda Protege Problems (gas cuts out?, read on)
Well, i cant figure out whats wrong
when in neutral, it revs just fine to 3k RPM or so, i havnt gone higher when im driving it seems like it gets power for 3-4 seconds, then cuts out (like back to idle), as if i had let up on the gas, i pump the gas 3-4 times and it runs again...then the cycle repeats, i just got a new muffler, and tires, i dont know if theres any wires that may be pinched perhaps.... im no expert, and i have no idea what certain RPMS sound like, i do shift pretty well, but from my view point, i think the car has been idling kind of high, although maybe thats just because my car has been running with basically ONLY a resonator (muffler/pipe were destroyed) and has been VERY loud its hard to tell my exact RPM since i have no tac, and to save money i skipped the resonator on my new muffler (VERY quiet) I dont know if its the transmission, fuel filter, fuel pump, fuel injectors, air filter, or what, but it seems like its not getting steady, consistant power please help!! it would be very much appreciated, im on a limited budget, and i just had to pay for new tires/install, and a new muffler, and i know theres repairs to come OH, also, last time i got my oil changed (about 1k miles ago) i was told that i needed new fan belts, any possibilty that they are slipping and causing the problem? Edit '94 protege ~118K miles regular oil changes as long as i have owned it... (10-11k miles) |
05-07-2007, 12:59 PM | #2 | |
Re: 1994 Mazda Protege Problems (gas cuts out?, read on)
anyone???
05-08-2007, 05:29 AM | #3 | |
AF - Advisor
What do you mean when you say the muffler and pipe were destroyed? Were they flattened because the car ran over something? Was the converter damaged? Any flattened or damaged exhaust system parts could cause a running problem. The EGR valve can also cause problems but it usally affects low engine speeds. The belts are not the cause of you running problem. Is your check engine light on? How does your air cleaner look? Without a more specific description it's hard to say what is causing the problem you describe. You can visually inspect the items I have mentioned at no cost to you, the EGR valve would need to be removed, tested and cleaned if working. Give us more information if you can.
Clifton |
07-10-2007, 12:43 PM | #4 | |
I'd have the fuel pressure checked. When you open the throttle, it lets in more air. The air sensor tells computer to tell the fuel injectors to open longer. If your fuel pump is weak, it behaves like you're not getting any gas. The fuel pump is under the back seat and easy to replace.
Change your oil every 5 thousand miles at the least. |
