Go Back   Automotive Forums .com Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-11-2018, 02:30 PM   #1
DrRadar
Just a guy
03 Explorer XLT: Driveline fluid changes
140k on 03 XLT and I'm ready to change driveline fluids.
Transfer case: It appears 1.5qt of Mercon. I've seen cautions against using Mercon V...to be sure the fluid is safe for transfer case. Still true?
Rear differential: 3.55 non-limited slip 8.8" (code 45): The manual says fluid is for "life" and doesn't need to be changed, but I'm skeptical. Proper fluid is synthetic 75W140 with "friction modifier" - correct? How much friction modifier?
Front differential: 80W90 - right? No friction modifier - right? Does it have to be synthetic? (I already have conventional 80W90 in garage.)
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
DrRadar is offline   Reply With Quote
Old 04-12-2018, 04:53 PM   #2
65comet
65comet's Avatar
Re: 03 Explorer XLT: Driveline fluid changes
The Mercon V is synthetic version of Mercon, great for transmissions built with the proper seals, but bad for everything else.
I can't comment on synthetic gear oil, I've always used standard. I know some racers swear by the synthetic, but they aren't going 100,000 miles or more between changes.
65comet is offline   Reply With Quote
The Following User Says Thank You to 65comet For This Useful Post:
DrRadar (04-13-2018)
