Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-07-2006, 03:56 PM   #31
Gizmo42
Gizmo42's Avatar
Re: P1404
I couldnt buy a mazda, too many ford parts
The 6 is built on the ford fusion platform and the 3 is built on the ford fungus platform. The good part though is they arent just rebadged fords, they have some mazda parts and styling. I do like the looks of the both the 3 and 6 though.
BTW, I would take an RX-8 if someone happened to give me one for my bday next month
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Gizmo42 is offline   Reply With Quote
Old 05-09-2006, 11:34 AM   #32
marcre
marcre's Avatar
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: P1404
I went to the junkyard today and of course there were no Rodeos in there. I saw some EGR's from Saturns and some other GM vehicles. They did look the same. I am going to go back and give it a try I think. The Saturn was a 97 and there was a Grand Am(?) that was a 96. I may take the one out of the Saturn, it looked better.
marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
marcre is offline   Reply With Quote
Old 05-11-2006, 08:39 PM   #33
marcre
marcre's Avatar
Re: P1404
The one I grabbed out of the Grand Am seems to be working fine. So far, no CEL.
My Rodeo
Old 05-12-2006, 02:12 PM   #34
rodeo02
Re: P1404
That's good info Marc! I knew I'd seen other GM vehicles with the same looking EGR valve. Do u remember what year/engine that GA had?
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 05-12-2006, 04:29 PM   #35
marcre
marcre's Avatar
Re: P1404
Joel
Not sure about the year, maybe a '96. There was a '97 Saturn that had a similar looking EGR in it, but it was harder to get at. There was a thread over on Planetisuzu (in Gizmo's post there is a link) that mentioned the interchangeability.
The engine I got it from was one of those 3800 V6's I believe.
marc
My Rodeo
Old 05-12-2006, 05:32 PM   #36
Gizmo42
Gizmo42's Avatar
Re: P1404
Hope it stays off for you now. Glad the GM part has worked, now thats 2 accounts of it working.
--Dave
Rear No-Slip Locker
Old 05-12-2006, 08:32 PM   #37
marcre
marcre's Avatar
Re: P1404
yea, it's off, so that's good. I did notice that the numbers on the tops of the EGR's are different, plus, they are different part numbers to order online. With that said, they look identicle except the connector is on the opposite side. The connector is identicle though,, and it does plug in fine. I would like to think that if it didn't work the CEL would come on. As far as it fitting, it drops right on perfect.
marc
My Rodeo
Old 01-16-2013, 02:38 PM   #38
dingobait
Re: P1404
I just pulled, and then erased, this code, P1404, which is supposed to indicate EGR issues.
Idle was very rough at times and eventually I got the CEL.
I disconnected the battery (which is key), and then disconnected and removed my Idle Air Control Motor (which is very simple).
The pintle and the port look clean.
I reinstalled the IACM, connected the battery, started it up, and drove. Runs great. Very smooth.
The CEL has not come on again yet.
Any time the idle gets rough, which has happened quite a few times in the 14 years I've had this car (currently at 254,600 miles), I pull and/or replace the IACM.
The key is to disconnect the battery, since if you replace the IACM without disconnecting the battery, the engine will run extremely rough, and could possibly damage it (?).
Once the battery is disconnected and then reconnected, the system calculates and sets the required parameters automatically.
Mark
Huntington Beach, Ca.
dingobait is offline   Reply With Quote
