Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 11-17-2011, 03:33 AM   #1
Longokemp
Need advice for 97 3000gt base
I came across a 97 3000gt base Coupe 2dr on sale. Everything seems to have the most recent tuneup to it.
122k miles, and ive always wanted to have this car. I've read a few reviews about the car and so far all the reviews have been nothing but good things but couple things that do scare me are that the common timing belt issue on the engine and also for you 3000gt owners, with the discontinuation, do you have trouble finding parts for the car? Does it take longer and cost more? And if twin car, the stealth, has the familiar body, will you be able to use some of the stealth parts for the 3000gt?
If there's anything else I need to know, I would love to hear your guys opinions
Thanks
Longokemp is offline   Reply With Quote
Old 11-17-2011, 06:39 PM   #2
Stealthee
Your worst nightmare
Stealthee's Avatar
Re: Need advice for 97 3000gt base
The 97 base 3000GT has the SOHC engine. The timing belt is not as big of an issue on that. If the car is an automatic, then it is basically a goood looking, but slow car.
It does share a lot of parts with the Stealth. Parts really aren't hard to find if you know where to look. There is a pretty good supply of vendors out there..
Stealthee is offline   Reply With Quote
The Following User Says Thank You to Stealthee For This Useful Post:
Longokemp (11-18-2011)
Old 11-19-2011, 11:26 PM   #3
Longokemp
97 3000gt test drive
Gonna be test driving a 97 base 3000gt with 120k+ miles. What are key components that I should be looking for?
thanks!
Old 12-02-2011, 09:15 AM   #4
AutostradaVR4
Just all the normal used car stuff...smoke, odd noises or smells, smooth shifts, no warning lights, etc.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
AutostradaVR4 is offline   Reply With Quote
Old 07-19-2012, 11:26 AM   #5
93driver
About finding parts, never had a problem finding anything for the 93 I have. Between all the wrecked GTs, ebay and salvage yards, no problems. Though the parts are a bit more expensive it seems unless you look around. But I haven't had to get a lot of parts either, so a lot depends on how well the car has been taken care of in the past.
I'd say don't let the 122k miles worry you as much as the typical signs of abuse, it's more about the maintenance and abuse than the miles I think. I got mine off a lot with 142k miles on it, now it's at 252k, and haven't spent a ton on it. My experience with the gt's has been fix a problem once & its stayed fixed, a honest mechanic helps tons, too.
YMMV, Good luck!
93 3000GT SL, 5sp, 250k+miles, all still stock
93driver is offline   Reply With Quote
Thinners advice for Zero Base Coat paints lotus123 Car Modeling 6 01-24-2009 05:42 AM
for sale 95 jetta runs needs work good project or parts car/ need advice for new car scooterman Jetta/Vento/Bora 0 01-03-2005 12:46 PM
need advice for 350 4 bolt main mister_higgs Street Racing 10 08-13-2002 04:00 AM
I need advice for brighter headlights phtogrnde 3 Series 1 07-17-2002 11:58 PM
