Go Back   Automotive Forums .com Car Chat > Mercury > Grand Marquis
Old 11-07-2011, 06:40 PM   #1
trixkit
2003 Grand marquis misfire cyl 8
Hi - I have a 2003 Grand Marquis that is misfiring on cylinder #8. I swapped the ignition coils from cyl 8 and 5, reset the codes and test drove. The misfire moved to cyl #5, so I replaced the coil. The car ran great for a day, then cyl #8 started to misfire again. When I removed the ignition coil from cyl #8 I noticed quite a bit of fluid in the chamber, partially covering the spark plug. I also noticed an exposed wire in the ignition coil connection. I taped the wire and cleaned up the fluid covering the plug and reinstalled the ignition coil. The car is running great now, but I suspect I have a leak somewhere that is going to once again get into the spark plug chamber and cause more misfiring. I'm not sure where the fluid is coming from or what it is. Looks possibly like antifreeze, but not sure.
trixkit is offline   Reply With Quote
Old 11-07-2011, 09:20 PM   #2
prmars
Send a message via AIM to prmars
Re: 2003 Grand marquis misfire cyl 8
Antifreeze present in the #8 spark plug well may indicate an intake manifold leak. I'd start by checking that the manifold bolts are properly torqued down and look for evidence of cracks in the plastic. There's a coolant gallery back there that goes into the head, so it's very possible that the manifold gasket has failed (possibly dried out and cracked from frequent heat exposure from the engine). It may only manifest itself when the engine is hot and running at or near full cooling system pressure (16psi).
I'd also check the thermostat, as it may be sticking and causing an unexpected increase in system pressure.
If a leak from the manifold is spraying on the COP at #8, it will definitely lead to a short and premature failure of the COP.
Others in the forum feel free to correct me on this one.
prmars is offline   Reply With Quote
The Following User Says Thank You to prmars For This Useful Post:
trixkit (11-08-2011)
Old 11-08-2011, 06:55 AM   #3
trixkit
Thanks for the reply.
You confirmed what I suspected. I do see mosture at the base of the intake manifold near cyl #8. Looks like the gasket could be failing or maybe I'll get lucky and it is the torque issue that you metioned. If the manifold is cracked that would be beyond my capabilities, so off to the shop.
Thanks again
Old 11-08-2011, 03:18 PM   #4
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
If the manifold is cracked, it is actually quite easy to replace. I did it several times using only a ratchet set, some pliers, and some printed off instructions free from the internet. Took me about 3-4 hours in my garage. Don't pay too much at a shop. After everything, I spent under $300, including the price for a brand new Ford Racing Performance Improved intake manifold (which is a direct fit, same thing you have on your vehicle now).
Get the engine to operating temperature and check the area around cylinder 8 after shutting the engine down while hot. You may be able to see/hear a little bit of coolant leaking. The cracks may not be visible when cold!
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
The Following User Says Thank You to Blue)(Fusion For This Useful Post:
Old 11-08-2011, 04:00 PM   #5
trixkit
Thanks, I'll see if I can spot the leak and perhaps try the replacement myself.
John
Old 11-10-2011, 08:38 AM   #6
auto trainy
A pressure test might reveal it ,good luck.
auto trainy is offline   Reply With Quote
Old 09-27-2016, 01:09 PM   #7
Nplummer
I am having the same problem except its on cylinder 1. I don't want to take the fuel rail off but its not the easiest to get a plug wrench down in there. Its also on of the narrowest I have come across. Like a lawn mower socket.
Nplummer is offline   Reply With Quote
2003 grand marquis LS Wiper Problem davizzel Grand Marquis 7 08-26-2018 02:09 PM
2003 Grand Marquis LS Exhaust Manifold pcmos Grand Marquis 6 10-07-2010 08:09 PM
2003 Grand Marquis A/C EATC Needs Replacement dabe Grand Marquis 7 07-12-2010 03:51 PM
2003 Grand Marquis Steering Problem m_damico10 Grand Marquis 1 12-04-2009 01:04 AM
2003 Grand Marquis FM reception brian duffany Grand Marquis 1 05-07-2009 10:28 AM
