| Latest | 0 Rplys |
12-22-2003, 03:54 PM | #136 | |||
Re: Srt4 Vs Wrx
Let's quote |delaysion|'s quote of himself: Quote:
And before you guys talk about turns, Neon ACRs have been wasting WRXs long before the SRT came out, and PVO used whatever Dodge has learned with that car on the SRT. An SRT-4 also wasted all the AWD-class cars at Pikes Peak, except one: http://www.srtforums.com/forums/show...threadid=21290 Just admit it. Especially in straight-line speed: STi > SRT-4 > WRX...plain and simple. Just as I go to SRTforums and challenge the SRT fanb0is, I am on here doing the same to the opposite side. ANd lastly, RACER D12: The SRTs are doing JUST fine over 300HP: http://fastattack.org/srtgurl/Fastes...mes%20List.htm Have you read the article in SCC about how strong the 2.4 motor is?
2002_Nissan_Maxima_6-speed
12-22-2003, 04:15 PM | #137 | |||
Some Guy
Re: Re: Srt4 Vs Wrx
12-22-2003, 04:21 PM | #138 | |
Yaya Master
Re: Srt4 Vs Wrx
carnutt its right...the srt4 can do pretty good even from a stand still despite being FF...srtgurl's still has an open diff and pulled a 12.6
the 04 will do much better with the quaifee though and about its handling...its very good...as i said just testdrive one and you'll be hooked the srt4 was very nimble its brakes were fenomenal and the engine pulled like a V8
(\__/) (='.'=) This is Bunny. Copy and paste bunny into your (")_(") signature to help him gain world domination |
12-22-2003, 07:15 PM | #139 | ||
Re: Re: Srt4 Vs Wrx
This is one of the longest threads I have seen that has not broke out into a flame war
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows |
12-22-2003, 07:27 PM | #140 | ||
Re: Re: Re: Srt4 Vs Wrx
If you're talking about daily driveable SRT-4's that can run sub 13 second 1/4 miles...yes you're probably right. A 12 second WRX can do it on the factory tires because of AWD, but the SRT-4 has to stop at the garage and swap out the street tires for some slicks if they wanna get the best times possible. |
12-22-2003, 08:29 PM | #141 | |
True but RWD is set up to get a lot better traction than FWD. However we are comparing the WRX vs the SRT so I was just making my case for those two. The second half of your post is what I was saying once you start going over that 300hp mark any FWD car is going to start having traction issues. Which is why the WRX will always be the fastest on the street. The SRT can only go so far on the street before it becomes "nose happy".
Edit:I mean in the end if you mod both, the WRX will be faster because the SRT can only go so far before it needs slicks
12-22-2003, 09:14 PM | #142 | |
Re: Srt4 Vs Wrx
I think you just have feather the clutch a little more w/FWD. Once you get moving it won't be an issue. We're talking 300hp not 800hp. I've heard SRT-4 drivers are pulling low 13 second and high 12 second times on street tires. Of course w/slicks the 60ft times are better, but the traps speeds are comparable.
12-23-2003, 01:27 AM | #143 | |
Yaya Master
Re: Srt4 Vs Wrx
and if i'm not wrong the ecu is programed for less boost in 1st gear so peeling out will not be a problem
even if you get over 300hp you can get a profec b and run very low boost in 1st then use the remote button to switch to high boost in second
12-23-2003, 02:32 AM | #144 | |
Just in case everyone has forgotten...Torque spins wheels, not horsepower. A 300hp fwd car isn't that big of a deal people. Especially not coming from a smaller motor with not all that much torque. You can have 900hp and 100lbs of tq and not spin the wheels. I don't think that 300hp in an srt would really be that hard to drive around on a daily basis(at least not as far as tires go). I mean, give it a couple years and that's what the Accord will be putting down.
There's no replacement for displacement...No, not even a turbo. |
12-23-2003, 03:20 AM | #145 | |
Self has a good point, but then again he knows whats up
There are so many variables, as well.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
12-23-2003, 10:04 AM | #146 | |
Re: Srt4 Vs Wrx
Yes Self I did not forget that tq is what makes wheels spin. The SRT motor though makes simular tq and hp numbers.
Steiner and Neutrino ya you can feather clutch reprogram the ECU like you said, but while your doing that the guy in the WRX can be going balls out. Plus then when you take into consideration the the road conditions and what not its just going to cause more problems for the SRT. So IMO WRX is the the better street racer.
12-23-2003, 03:05 PM | #147 | |
Yaya Master
Re: Srt4 Vs Wrx
and its a true an AWD car will always win the launch...but you forget one thing....AWD hard launches are murder on your transmission and clutch....why do you think everyone keeps saying that the evo and sti are not drag racers
12-23-2003, 03:23 PM | #148 | ||
And a high powered FWD doesnt ALWAYS need slicks to go fast when drag racing..... example: Hybrid & DohcCam's CRX.
when in doubt, throttle. |
12-23-2003, 03:30 PM | #149 | ||
Re: Re: Srt4 Vs Wrx
I've seen a couple videos of "SRT-4 vs. WRX" races. From a roll the SRT-4 pulls from the 3rd beep of the horn and doesn't stop until the race is over. From a dig the WRX hooks up impressively, but the SRT-4 pulls like a mutha once the driver shifts into 2nd gear. |
12-24-2003, 01:48 AM | #150 | |
On Fire!
If you guys are questioning driveability of a high powered car of any type. You got to remember it's your right foot that controls the throttle. The car will only go as fast as you want it to.
I learned that when I learned how to ride my motorcycle. It'll only go as fast as I let it.
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
