Go Back   Automotive Forums .com Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 11-29-2008, 04:27 PM   #1
C4 Restore
severe orange peel in my paint
I have a 91 corvette. I sanded the original finish with 320 grit sandpaper, cleaned the surface with wax and grease remover then tack clothed after prep. sprayed a mist coat of black epoxy primer then 2 wet coats with only hardener. the last coat of epoxy, I added mid temp reducer as directed to create the sealer. before applying sealer the primer was slick but lots of orange peel. after spraying the epoxy reduced as a sealer everything turned a nice dull black and was really smooth with no orange peel. 3 days later I tack clothed again and sprayed a single stage black urethane paint on with mid temp reducer at about 63 degree air temp.I test sprayed a bunch of old slick parts first and let them flash and the finish on the old parts came out nice and slick the way it should look so I sprayed the vet with those gun settings. the paint severly orange peeled in the end. for the 3rd coat I tried adding a little more reducer to smooth the finish but with no luck. what went wrong ?? why did the parts come out great test spraying but the car did not ? can I re-sand the new finish and try spraying again till I get it right and if so what grit of paper do u reccomend to re scuff for another try ? the gun was a 1.4 mm tip HVLP gravity feed and the pressure regulator at the gun was set on about 40 psi so I could get a consistent 35 psi. any help would be greatly appreciated.
C4 Restore is offline   Reply With Quote
Old 12-18-2008, 08:11 AM   #2
LearnAutoBody
Auto Body Mod
LearnAutoBody's Avatar
Re: severe orange peel in my paint
You may try turning your PI down to 20 PSI. Try this and see if it helps.
LearnAutoBody is offline   Reply With Quote
Old 03-31-2009, 07:23 PM   #3
danielsatur
HVLP = High volume (paint) Low pressure (air)!
danielsatur is offline   Reply With Quote
Old 04-02-2009, 07:27 AM   #4
Mark Lapes
Sometimes orange peel is also cuased by using the wrong thinner { under diluted }. With a fast evaperating thinner it will cause atomized to be dry before they hit the surface.
Mark Lapes is offline   Reply With Quote
