| Latest | 0 Rplys |
10-09-2016, 10:09 AM | #1 | |
02 ram 1500 emissions
I bought the truck used several months ago, had some computer issues and the catalytic converter clogged up. all that has been replaced, my question is I am getting a p0455 code with is emissions large leak. from the canisters under truck a hose comes out of the canisters to the leak detection pump the to small round filter looking things. then it connects to a plastic pipe heading toward the motor. but it is just an open pipe about 18" away. where does this connect so that I can clear the p0455 code?
10-09-2016, 01:30 PM | #2 | |
Your worst nightmare
Re: 02 ram 1500 emissions
The line you are talking about is likely supposed to be open. Your code could be caused by a faulty purge valve, or a series of other issues.
10-09-2016, 03:24 PM | #3 | |
what are the other issues?
10-09-2016, 04:06 PM | #4 | |
Its one of those things that need diagnosed. I usually find that Googling the DTC number finds several results that usually include ways to diagnose the issue.
10-09-2016, 08:36 PM | #5 | |
AF - Advisor
From an '01 FSM,
P0455 Evap Leak Monitor Large Leak Detected. A large leak has been detected in the evaporative system. Could be a bad gas cap not holding vacuum to the fill lines to fuel vent lines not sealed....just have to start looking.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
Thread Tools | |
