Go Back   Automotive Forums .com Car Chat > Honda > MDX | Pilot
Old 06-29-2010, 10:30 PM   #1
listenloud
2005 Pilot - Gurgling Rattle Under Dash Pass side
I have an odd intermittent gurgling noise coming from the lower passenger side of the dash. I seems to be coming from the area of the heater/ac box. It's not related to the heater motor. No change when heat/ac is off or on or when fan speed is changed. There is no distinct pattern of the noise. It sounds like someone blowing bubbles in a cup, but with more of a click type noise.
Any ideas?
2008 Honda Civic EXL - Daily Driver
2000 Silverado 1500 LT - Boat and Haul
2005 Honda Pilot EXL - Wife and Kids
1997 Ford Mustang Cobra Convt. - W/E
listenloud is offline   Reply With Quote
Old 06-30-2010, 01:16 PM   #2
somick
somick's Avatar
Re: 2005 Pilot - Gurgling Rattle Under Dash Pass side
Have you checked the coolant level?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 07-03-2010, 05:55 PM   #3
listenloud
I usually check it when I change the oil. I thought it had an indicator light to show when it's low. I'll take a look. Thanks.
Old 07-04-2010, 09:56 PM   #4
somick
somick's Avatar
Indicator light comes on for a low oil level not for coolant. By the way when the light comes on it is usually too late: oil level dropped below 3 quarts which is very bad for the engine. Your bearings are starving for lubricant.
Check the coolant level in the expansion tank first. If god forbid it is empty, wait for the engine to cool off and open the radiator cap. It suppose to be full. Make sure you use only Honda approved fluids.
Good luck,
Sam
Old 07-05-2010, 08:48 AM   #5
listenloud
Coolant was OK. I found this posted on another site.
Doing some diagnostics...Long screw driver to components under dash to isolate noise...this little guy appeared to be the culprit.
The Blend control motor:
$238 list / $190 from my friendly local
dealer...20 minutes laying upside down under the dash.
RESOLVED!
This image has been resized. Click this bar to view the full image.
Old 07-07-2010, 12:56 PM   #6
somick
somick's Avatar
I hope it will work for you too.
Good luck,
Sam
