04-10-2008, 08:37 PM | #1 | |
88 rough surging idle
2.9L MPI - Will die on cold start unless you bump the gas for a few seconds and keep the idle up around 2K. Later, will often surge and a stop, or just idle rough.
Replaced plugs (suspect), wires, IAC valve, checked intake for leaks. I suspect the plugs because I bought these fancy platinum no-gap plugs. I think I changed too much at once. Ideas? |
04-11-2008, 02:54 PM | #2 | |
A990 racer
Re: 88 rough surging idle
Welcome to AF, general symptoms, but this is a 2.8 Chevy correct? Check for fuel pressure at the rail, also major vacuum leaks. Check for both injector fuses being good also.
01-10-2012, 11:50 AM | #3 | |
I know this post is 4 years old, but did you figure the problem out?
01-10-2012, 03:03 PM | #4 | |
A990 racer
If you have the same issue be sure to look at the egr also, that was common for not seating causing stalls and hesitation. with the 2.8.
01-31-2012, 02:46 PM | #5 | |
Thanks for the suggestion. The EGR was relitively clean, and I cleaned the IAC valve as well. The problem remained..BUT, I obtained a shop manual and I figured it out.
It seems that the power steering pressure has a lot to do with the idle control when the engine is at operating temp. I found leaking and cracked power steering hoses, as well as power steering pump seals. I replaced them all, and my surging idle issue is gone. My Cimarron is an '86, lets see if these new hoses and seals last another 26 years. |
