| Latest | 0 Rplys |
04-25-2016, 12:13 AM | #1 | |
2001 Dodge Ram 4x4 1500 Quad Cab
turn the key, engine won't turn over, straight hook up starter with battery cables, starter spins engine won't turn, all lights come on on instrument panel, checked all fuses, relay, etc..solenoid won't kick gear into flywheel, need some good sound advise. Can't find any threads with similar problem, thank you Dodge fans
Last edited by foxtrotsam2; 04-26-2016 at 10:22 PM. Reason: no answer, thread too long? |
04-27-2016, 07:07 PM | #2 | |
AF - Advisor
Re: 2001 Dodge Ram 4x4 1500 Quad Cab
Sounds like the starter contacts inside the starter solenoid are burned up so time to replace the starter.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
05-11-2016, 07:50 PM | #3 | |
Did you figure it out?
05-12-2016, 10:13 PM | #4 | |
we had a mechanic look at it and advised that hooking battery cables backward does haywire and insane results to the sensors even though instrument cluster lights up and everything, I mentioned about the starter and he said it would do that, so we are giving up on it, at least for the time being, thanks to all anyway, (the red bat cable was hooked up to ground and the black ground cable to the positive post) that's when everything happened.
