Old 02-24-2002, 06:12 PM   #91
Jay!
Horizontally Opposed
Originally posted by daggerlee
Build a shrine to the Gods of Disappearing Small Parts
Next time when those small handbrakes fall onto the floor just offer a few styrene sheets as sacrifices and they'll turn up in no time!
If only I knew that a year ago...
Hierarchy of Subaru:
(Click to see mine!)
Jay! is offline   Reply With Quote
Old 03-01-2002, 04:17 PM   #92
Rob80
Send a message via AIM to Rob80
I did this
Originally posted by Chris
DO NOT SPILL MODELLING GLUE ON CLEAR WINDOWS!!!!!
If you do, just leave it alone, you will only make it worse by touching it. Do not use scotch tape on a clear-coated surface shortly afte painting it. Do not spray one heavy coat, two or more light ones. Do not spray 2 or more heavy coats, either.
I got glue on a window and i tried lightly sanding it off with really fine sand paper, hahahahaha, don't do it, you will make a mess!!!!
Rob80 is offline   Reply With Quote
Old 03-01-2002, 04:25 PM   #93
Rob80
tell me about this one
Originally posted by ales
Put your painted model bodies (I'm talking die-cast here) somewhere they can't fall off from (LIKE THE FLOOR!), and also there shouldn't be anything that can fall on them. It sucks twice as much when a nice black car falls on the nice white-primered car and the former gets a huge scratch on the roof, and the latter gets it's scratch-built DTM rear wing knocked off!!!
But it's OK now...
I was almost done with a ford probe (no questions, I owned one but I now drive a civic) and someone took it out with a pool stick and it then fell to the floor. to top things off the person started stepping on the parts. The model is still not finished, I guess I gave up. To complete this story, my friend and I started building a custom 56 ford pickup truck from random parts that were laying around and that one also hit the floor and remains in pieces. After reading these posts I might have to finish the models though.
Old 03-01-2002, 04:42 PM   #94
Rob80
lathe
Be careful with sharp knifes.
I'm doing the Tamiya WRX kit and had been to work to use the lathe to make up some small rim spacer's for some different rims i'm fitting to the kit.
metal lathe? I have a wood lathe and a metal lathe and don't even know how to use the metal one. What exactly did you make with it?
Old 03-01-2002, 04:53 PM   #95
Rob80
ketones
Originally posted by yater13
Never use brake cleaner. It's brake FLUID that will strip the paint, not cleaner. Most brake cleaners are made from MEK (methal ethel ketone, sp?) which will melt most plastics very quickly.
most ketones will melt plastics, its a good organic solvent.
Old 03-01-2002, 06:10 PM   #96
darrenj
darrenj's Avatar
window cutter
You want a great view of your to rally drivers in your Subaru WRC diorama because the pastic windows make them look distorted. So you cut off the window off the car and then decide to put the window back two hours later!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NO:::: GLUE FUMES F*** it the windscreen
darrenj is offline   Reply With Quote
Old 03-03-2002, 03:15 PM   #97
thrill me
Send a message via ICQ to thrill me Send a message via AIM to thrill me
Unhappy
Once when i had bought a new swiss army knife (sharp as hell) i opened the large blade and then i droped it down on to my finger, deep cut. I was bleeding forever, anyway, dont do that it hurts!
thrill me is offline   Reply With Quote
Old 03-04-2002, 07:32 AM   #98
Tom_S8
Tom_S8's Avatar
Send a message via AIM to Tom_S8
Originally posted by Minerale
Once when i had bought a new swiss army knive (sharp as hell) i opened the large blade and then i droped it down on to my finger, deep cut. I was bleeding forever, anyway, dont do that it hurts!
It hurts? Hm , i can't belive you , gotta try that myself ...
Tom_S8 is offline   Reply With Quote
Old 03-04-2002, 07:53 PM   #99
Cobber
Cobber's Avatar
YOU CAN NOT SLOW YOUR DREMEL TOOL DOWN SLOW ENOUGH TO MIX PAINT
You can try but your finger and thumb get way to hot to hold on to the collet, and you end up letting go.
I ended up with a 4" black stripe on my chest(soaked through my shirt) for a week.
Cobber is offline   Reply With Quote
Old 03-05-2002, 05:59 AM   #100
yater13
Send a message via AIM to yater13
Don't attempt to reinsert a spray can nozzle anywhere near a prepped model. Splatter texture doesn't look to good on a model.
yater13 is offline   Reply With Quote
Old 03-05-2002, 06:56 AM   #101
thrill me
Thumbs up Heres one!
Don't let your little brother pick all of the parts of the frame..
You were born crying with people standing around you smiling.
Live, and you might die smiling with people standing around you crying.
Old 03-25-2002, 04:50 AM   #102
ales
Forza Schumacher
ales's Avatar
Humbol matt black (33) is anything BUT matt!
Old 03-25-2002, 02:03 PM   #103
nismo kid
You're avvin a laaaaafffffffffffffffffff...
You have got to be kidding. I have had no problems with any humbrol matt enamels. I've had several matt blacks since i started doing models and hae had no problems with any of them. I think I have figured out your particular problem though.
Stir it!!!!!!!!!!!!!!!!!!
Rich.
nismo kid is offline   Reply With Quote
Old 03-25-2002, 02:14 PM   #104
Lownslow
Lownslow's Avatar
never sand BONDOnear a lit candle
Lownslow is offline   Reply With Quote
Old 03-26-2002, 01:01 AM   #105
ales
Forza Schumacher
ales's Avatar
Re: You're avvin a laaaaafffffffffffffffffff...
Stirred, shaken, warmed, etc. Still, compared to Revell (nr 8) , it's more like semi-gloss.
found what the problem was the hard way Helixrider Sportage 2 12-06-2006 11:15 AM
What Pictures do you have on your hard drive? taranaki COMPLETELY off-topic 21 02-22-2003 01:15 PM
Just learnt something new, the hard way... hermanchauw Car Modeling 9 01-24-2003 06:44 PM
two things i've learned the hard way... appleseed Car Modeling 6 01-20-2003 08:29 PM
A tip i found out the hard way! supratuner Car Modeling 6 01-12-2003 07:35 PM
