Old 01-08-2002, 02:49 AM   #76
4x4 Cactus
expect your decals to melt in 30 miniutes if not properly dried!
4x4 Cactus is offline   Reply With Quote
Old 01-08-2002, 02:50 AM   #77
4x4 Cactus
I mean when you spray clear of coures!
Old 01-16-2002, 09:46 PM   #78
Murco
Maximum Car Guy
Murco's Avatar
Send a message via Yahoo to Murco
Make a vacuum former from a 5"x7" electronics box and same size perforated board from Radio Shack. Attach the board to one end of the box with a hinge, and use 5/32 vacuum hose tubing around the opening af the box to seal it. Attach your vacumm cleaner's hose to the box for the vacuum source (a sliding vacuum bleed-off is recommended to avoid over-powering the plastic) and you can form windshields from heated acetate, body parts from heated styrene, and many other neat products for your model! You can create a pattern for a spoiler from clay and pop out as many as you like!
My AF Classic Model Car Gallery
Murco is offline   Reply With Quote
Old 01-16-2002, 09:51 PM   #79
Murco
Maximum Car Guy
Murco's Avatar
DO NOT USE AUTOMOTIVE WAXES ON MODEL FINISHES!!
They often contain silicone and can actually prevent your paint job from "gassing-out" and also create havoc when applying decals, or attaching parts like mirrors. In the worst case, your paint will begin to crack in a pattern similar to a dry-lake bed in a dry-spell!!
Use only products specifically for model finishes or Meguiars glaze products.
Old 01-16-2002, 10:13 PM   #80
Murco
Maximum Car Guy
Murco's Avatar
I also screw up windows pretty much constantly. You can use some Krystal Klear or something (ask Jay)
Try some watch crystal cement, works wonders!!!
Russ
Old 01-23-2002, 06:40 PM   #81
yater13
Send a message via AIM to yater13
Originally posted by HuMMerMan
Heres a real good one.
If you need to strip the paint off a kit. DO NOT USE BRAKE CLEANER
Never use brake cleaner. It's brake FLUID that will strip the paint, not cleaner. Most brake cleaners are made from MEK (methal ethel ketone, sp?) which will melt most plastics very quickly.
yater13 is offline   Reply With Quote
Old 02-02-2002, 01:01 PM   #82
87accordlx
87accordlx's Avatar
Send a message via ICQ to 87accordlx
Angry
when spraying your models make sure everything u don't want to make that colour is off the table, i was over anxios and got baby blue overspray all over my decal sheet
scott
87accordlx is offline   Reply With Quote
Old 02-03-2002, 02:54 AM   #83
tazdev
I'm still here
tazdev's Avatar
Tamyia enamel paints don't seem to paint well over AS-12
has anyone else noticed this????
tazdev is offline   Reply With Quote
Old 02-03-2002, 04:39 AM   #84
Jay!
Horizontally Opposed
Couldn't tell you. There's something about the "AS" paints that makes them illegal to sell here in America. We only get the "TS" spray cans. And to tell the truth, I've never seen the Tamiya enamel jars, only the acrylics.
Hierarchy of Subaru:
(Click to see mine!)
Jay! is offline   Reply With Quote
Old 02-05-2002, 04:54 PM   #85
nismo kid
Here's a useful one...
Never attempt to apply decals while wearing boxing gloves.
Rich.
nismo kid is offline   Reply With Quote
Old 02-06-2002, 01:59 AM   #86
tazdev
I'm still here
tazdev's Avatar
turns out that it was just 1 bad batch of paint, I had a second little jar and tried some of that and it was fine
Oh yeah. Never handle a light colored model with dirty fingers
Old 02-08-2002, 01:29 AM   #87
tazdev
I'm still here
tazdev's Avatar
NOTE. the Loctite Zexel R34 GTR uses a different exhaust to the Pennzoil R34 GTRbut both are included in the kit. I accidentally used the one from the pennzoil car and had to cut the end off and put the correct end on
make sure you use the correct one
Old 02-13-2002, 06:20 PM   #88
nismo kid
Dont even bother with humbrol spray paints. My model shop guy sold me saying they are 'the same as the tamiya ones.' My a** were they.
Also don't try to spray over humbrol paint with halfords paint. Not even after it has fully dried. In fact, I've tried spraying more humbrol paint over dry humbrol paint before and it has messed up (it goes all wrinkly)
I've given up on it now. It's either halfords or tamiya for me from now on.
Rich.
Old 02-16-2002, 05:37 AM   #89
primera man
"P-Man"
primera man's Avatar
When applying any decals....NEVER use an old brush that has paint in it because if you use Micro Set on you decals it cleans any paint out of the brush onto your dacal.
Only ever use a brand new brush that has never had paint in it.
View All My Models Here.
primera man is offline   Reply With Quote
Old 02-24-2002, 06:06 PM   #90
daggerlee
daggerlee's Avatar
Build a shrine to the Gods of Disappearing Small Parts
Next time when those small handbrakes fall onto the floor just offer a few styrene sheets as sacrifices and they'll turn up in no time!
daggerlee is offline   Reply With Quote
found what the problem was the hard way Helixrider Sportage 2 12-06-2006 11:15 AM
What Pictures do you have on your hard drive? taranaki COMPLETELY off-topic 21 02-22-2003 01:15 PM
Just learnt something new, the hard way... hermanchauw Car Modeling 9 01-24-2003 06:44 PM
two things i've learned the hard way... appleseed Car Modeling 6 01-20-2003 08:29 PM
A tip i found out the hard way! supratuner Car Modeling 6 01-12-2003 07:35 PM
