Go Back   Automotive Forums .com Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 04-14-2012, 07:17 AM   #1
ellev8or
Towing 67 Pontiac Bonneville
Greetings,
I have a few important questions that I need advice on and I thank you in advance.
My Bonneville needs to be transported because I've relocated. I've gotten a heap of quotes from various auto transporters but pricing and reputation is a major factor.
I believe if I tow it myself I would certainly have ease of mind.
The Bonneville is topped off with gas and I don't believe it would be safe to perform a 24 hour travel with that much fuel in the tank. Would you ladies and gentlemen agree?
I would like to remove 95% of the fuel and I don't plan on going it the old-fashioned way; mouth-to-garden hose method. I've been racking my brain on a more convenient way since the tank is so low to the ground and fuel entry point is at the rear. I've been looking at the fluid pumps and syphon systems but having difficulty choosing. I'm open to any cost effective suggestions.
Also, do you think it would be safe to use a U-Haul auto transport trailer for the Bonneville. I've researched the size, weight and wheel base and it appears to be doable. The Bonneville's weight is at 4115 lb. I would be towing it with a later model Chevy Suburban.
The plan is to take my time while in tow and travel on lower grade roads with fewer inclines and declines.
Please inform me if I'm missing or overlooking anything.
Thanks!
SSL
ellev8or is offline   Reply With Quote
Old 04-14-2012, 10:43 AM   #2
maxwedge
A990 racer
Re: Towing 67 Pontiac Bonneville
Any siphon set up commonly used for marine apps. should do. Make sure the rented trailer is large enough and in good shape, that is of course a heavy car, the Sub will be good to go for the tow.
maxwedge is offline   Reply With Quote
The Following User Says Thank You to maxwedge For This Useful Post:
ellev8or (05-01-2013)
Old 02-28-2013, 05:42 AM   #3
ziggy55
Greetings Good sir,
Although piece of mind is priceless attempted this same feat and burned out the transmission on the car I was towing. Apparently I had to disconnect the transmission on the Lincoln I was towed. My advise would be to give the auto transport a try. I've used a company called American auto transport move they have a rate calculator on there web site for quick quotes and the prices are reasonable once you take all the factors of doing it yourself. This is their web site americanautomove.com hope this helps!
Ziggy
ziggy55 is offline   Reply With Quote
The Following User Says Thank You to ziggy55 For This Useful Post:
Old 02-28-2013, 09:13 AM   #4
maxwedge
A990 racer
Nice concealed spam Ziggy, they just happen to be based out of FL, also this a year old thread, please no more, thanks
1994 Pontiac Bonneville Problems!!! bridget36907 Bonneville 8 06-29-2011 07:20 PM
program a remote for a 1998 Pontiac Bonneville SE chopper32 Bonneville 2 04-15-2003 12:02 PM
98 Dodge Intrepid & 01 Pontiac Bonneville SSEI keyless entry programming? PSORC1 General Discussion 1 10-04-2002 09:58 PM
program new and also 2nd remote entry for pontiac bonneville tom_e37921 General Discussion 0 07-29-2002 01:33 PM
1994 Pontiac Bonneville vs. 1989 Z24 dbartoschek Street Racing 2 06-14-2002 04:38 PM
