Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 10-05-2010, 06:59 AM   #1
jpdoyle
97 Ford Contour rear end rattle
I have rattle in the rear of the car somewhere that is very noticeable on slightly rough roads. It sometimes makes a loud clunk that sounds like metal against metal. Took it to a local Big O tire and the said it was sway bark links and rear struts that need replacing. Visual inspection I can't see anything wrong with the bushings or linkage in the sway bars. They seem nice and tight with no visible wear or damage. Any ideas?
jpdoyle is offline   Reply With Quote
Old 10-05-2010, 02:57 PM   #2
Davescort97
Escort guy
Re: 97 Ford Contour rear end rattle
Before replacing the sway bar bushings or the struts I would first check the mounting bolts and nuts. Sometimes the rubber in the bushings gets loose as it gets older and it need to be tightened up some. There was some very good advice in a related post stating that in the inside of the muffler the baffles could have come loose. I'd grab onto the tailpipe and give the system a good shake.
Davescort97 is offline   Reply With Quote
Old 10-05-2010, 10:00 PM   #3
jpdoyle
Thanks Dave I'll give that a try.
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
95 ford Contour rear strut toneysimmons Contour 3 02-17-2009 06:23 PM
Rear end rattle thumper89 Lebaron 3 09-30-2007 08:11 PM
Rear end Rattle XGamesJ6 Cutlass Series 0 06-04-2006 09:03 PM
