Go Back   Automotive Forums .com Car Chat > Nissan > Frontier | Navara
Old 09-22-2007, 07:05 PM   #16
kappmaestro
Re: Air bag light!!
Thanks guys it really does work. I tried this on a 95 Nissan sentra. Hit the door switch 7 times and then started the car and the light was gone. awesome!
kappmaestro is offline   Reply With Quote
Old 01-10-2008, 12:21 PM   #17
nowrb
Re: Air bag light!!
Originally Posted by mblgasman
2001 Frontier-reset Airbag Light.
1. Open Drivers Door.
2. Turn Key On Until Airbag Light Comes On.
3. Turn Key Off & Close Door.
2001 Frontier-get Air Bag Codes.
2. Turn Key On Until Air Bag Light Comes On-it Takes Approx. 7 Secs.
3. Turn Key Off & On Within 1 Sec. After Airbag Light Comes On.
4. Repeat This Three Times.
These Sequences Will Get You Somewhere.
This sequence worked to reset the airbad light on a 2002
nissan frontier, THANKS VERY MUCH !!!!
nowrb is offline   Reply With Quote
Old 02-07-2008, 02:07 PM   #18
freetelecon
freetelecon's Avatar
Exclamation Re: Air bag light!!
Just did the Nissan Frontier air bag light reset.. was aggrivating @ first! DO IT THIS WAY..
1.Sit in truck with door open
2.Put left hand on door switch
3.Put key in ignition and turn only till dash lights come on (DO NOT START) and IMMEDEATLY PUSH DOOR SWITCH 7 TIMES.
4.AIR BAG light will flash slow and stop.
5.Press door switch. Turn off key.
wait a moment just because... start truck... should be reset
I used to do it sitting in the truck/car ALL the time at the dealer.. I forgot and was going CRAZY! You have almost no time to hit the switch upon turning on the ignition.
NOTE: ignore any comments about where to click the key switch.. on, acc, etc. JUST TURN ON ONLY TILL DASH LIGHTS COME ON.
>>>NO STARTING<<<
freetelecon is offline   Reply With Quote
Old 02-11-2008, 07:41 PM   #19
dugan50
Authorized Vendor
dugan50's Avatar
Re: Air bag light!!
On most vehicles, the airbag light should come on for @6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. Most systems can only be diagnosed using a scanner designed for the airbag system, however some use flash codes to indicate the problem. The scanners at Auto Zone or the ones that sell for @ $50 will not access the airbag system, only the engine systems (check engine light).
This website gives you the procedure for diagnosing and resetting some systems without a scanner. Some vehicle manufacturers accommodate that (like Toyota, Lexus, Nissan, Infinity, Honda, Acura, Ford, Lincoln, Mazda & Mercury) and some require a scan tool. http://www.airbagsolutions.com/
Check out these websites also for more info on airbag systems and the light.
http://blog.airbagsolutions.com/arch...ould-i-do.aspx
http://www.airbagsolutions.com/resources.aspx
Check out this scanner for AIRBAG>>>It’s the cheapest one I’ve found!
http://www.airbagsolutions.com/scanner.aspx
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
dugan50 is offline   Reply With Quote
Old 04-05-2009, 04:30 PM   #20
theoldfrontier
Re: Air bag light!!
Ok, Here is my experience with my 99 Frontier. The FIRST time it happened (at around 100K), and the 7 blinks with the door switch method previously described, worked. The SECOND time, this method did not work. Then I noticed that the airbag light was blinking the 8 blink code for the passenger air bag. So I took the 4 screws out of the top of the glove box and sure enough the airbag conector was no longer connected. I connected it, and tried the 7 blinks with the door switch several times, but it did not work. So thinking I needed to clear the 8 code, I blinked the door switch 8 times, and this caused a slowing of the air bag light, and no 8 code. I turned off the key, THEN I tried the 7 blinks on the door fix, and it finally stopped!
theoldfrontier is offline   Reply With Quote
Old 12-08-2009, 09:08 PM   #21
avargas159
Re: Air bag light!!
Thanks for the post.
I had that problem In my 96 sentra GLE I just follow the steps and it works!!!!
This tip save me a lot of money thanks!!
avargas159 is offline   Reply With Quote
Old 04-14-2010, 01:16 AM   #22
06frontier
Re: Air bag light!!
Has anyone done this on a 06 or above nissan frontier? I have been trying the different ways as described and nothing works. Any help on this will be helpful. Also I have my tire pressure light on as well. I'd like for that to go away as well. HELP!
06frontier is offline   Reply With Quote
Old 05-14-2010, 06:41 PM   #23
sharonmg
Re: Air bag light!!
turn the ignition key on, when the light comes on, turn it off. do this 5 times. worked on my 2004 frontier xe
sharonmg is offline   Reply With Quote
Old 05-14-2010, 06:53 PM   #24
sharonmg
Re: Air bag light!!
turn the ignition on then off when the light comes on. do this 5 times. it'll reset it. I have a 2004 XE and it worked. started flashing when I was working on my stereo and I had to disconnect the connector to the airbag light.
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
96 abs & brake light, air bag light all on bobkhi Dakota 1 09-15-2006 10:37 AM
check engine light and air bag light are on! ur_06 Accent | Verna 1 01-05-2005 04:43 PM
