Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-15-2019, 08:27 PM   #1
deerefeed
2016 Camry LE click noise when applying brakes in reverse only
My car makes a click noise, sometimes two different click noises in the front area when backing up and applying the brakes. I can roll forward and apply the brakes and there's no noise but every time I back up I hear a click when applying the brakes. Is this normal or something I should have looked into?
deerefeed is offline   Reply With Quote
Old 12-15-2019, 10:22 PM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: 2016 Camry LE click noise when applying brakes in reverse only
Have your brakes inspected. They may need replacing or just some grease on the moving points. Also check your CV boots for leaking grease. Replace them if they are leaking.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
