Go Back   Automotive Forums .com Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 01-11-2006, 07:04 AM   #46
Senor Schlep
98 Trooper 77,000 Mi. Purchased With 50k,no Problems So Far. Just Replaced Shocks & Fuel Filter.
88 Trooper 357,000 Mi. Third Owner
2.6 Motor Completely Rebuilt 16,000 Mi Ago For The Second Time.then It Started Pouring Out Smoke,now It's In The Shop Having A New Head Put On. I Will Be Worth It. Want To Go For 500,000 Mi.
Senor Schlep is offline   Reply With Quote
Old 01-11-2006, 10:04 PM   #47
koolcutta
2002 Isuzu Trooper s
68400 miles
only problem is P1125
koolcutta is offline   Reply With Quote
Old 01-12-2006, 08:21 AM   #48
jt_uk
Send a message via MSN to jt_uk
1995
3.1 Turbo Diesel
126,000 Miles
Waterpump, starter motor plus the usual (belts, cv gaiters)
jt_uk is offline   Reply With Quote
Old 01-13-2006, 08:09 PM   #49
Mentalman
Angry Re: How many miles do you have your Isuzu?
2000 Isuzu Trooper 3.5l
49,000 miles
Currently has a blown motor. Fighting Isuzu to replace it. Warranty ran out in May 2005.
Mentalman is offline   Reply With Quote
Old 01-13-2006, 08:19 PM   #50
PeteCal
Re: Re: How many miles do you have your Isuzu?
49,000 miles
The warranty on my 1998 was 60,000. #1 bearing went at 63,000. I had "a little discussion" with the dealer and rep. They replaced the engine. I paid for a new oil pump (~$200). I also paid for a new timing belt to be put in at the same time.
Don't give up the fight.
2007 Tucson (wife)
2014 MKX
"I am not going to live long enough to do all I want to do"
PeteCal is offline   Reply With Quote
Old 01-13-2006, 08:42 PM   #51
Mentalman
Re: Re: Re: How many miles do you have your Isuzu?
I also had a "little discussion" with the local dealer, and the Isuzu folks at the "complaint Dept" I believe in Colorado. They refuse to do anything. They say if I cannot provide proof that I changed the oil every 3,000 miles, They cannot help me. I did indeed keep the oil changed on a regular basis, but more like every 4,000 to 4,500 miles. However, I didn't feel I needed to keep all of my receipts. My attorney and I are discussing our options. #1 file a class action civil suit. This will be a massive search for all people that have had, or are currently having, the same problem I did (massive oil consumption), and pull them all together to sue Isuzu. #2 just go to small claims court to try to prove the 2000 3.5 litre engine was manufactured with defective Pistons, rings, cylinders and oil ports. We'll see.
TRUST ME. I will not give up the fight. I work as an administrator at a county prison, and have had 15-20 attorney's tell me they are willing to help anyway they can. I also have two county judges as friends that are interested in this. Just a matter of time.
Old 01-14-2006, 02:12 PM   #52
00trooper
3.5L V6
66K
Tranny seems to jerk btwn 1st & 2nd but at timse shifts fine.... otherwise good!
00trooper is offline   Reply With Quote
Old 01-14-2006, 09:56 PM   #53
mark2842
89' trooperII
2.6L 4cyl
248,000 miles
2nd owner, only problems is surging when engine gets warm and running hot(not overheating) just running hot
mark2842 is offline   Reply With Quote
Old 01-26-2006, 01:51 PM   #54
raptorchevy
Year:1991 Trooper
Engine:2.8 5speed
Mileage:319,000
Any major problems:Not now, Just rebuilt engine and stroked it to 3.1, idler cam and blue printed and balanced. replaced all bushings and undercarriage stuff.
2001 Silverado 2500 ext Cab short box
FIPKIII
Hypertech Power programmer
Cant wait to mod more
1991 Isuzu Trooper SE
2.8l stroked to 3.1l
Idler performance Cam phase II
4.3 TBI 1' Airraid TBI Spacer
Blue Printed and Balanced
1988 RX7 Convertible
Ported, headers, custom exhaust, elec fan
raptorchevy is offline   Reply With Quote
Old 02-06-2006, 09:07 PM   #55
ND Guy
1989
2.6 4cyl
189,800 miles
Needed to replace engine, replaced with one from my 1991 Trooper with 144,000 miles, also replaced clutch at the same time. No rust, nothing else major is wrong with it.
I also have another 1991 Trooper
2.6 4cyl
152,300 miles
Have had problems with front auto hubs. Engine is very strong.
ND Guy is offline   Reply With Quote
Old 02-13-2006, 07:21 PM   #56
i2i
Year:1993 (Trooper) LS
Engine:3.2 DOHC
Mileage:189000
Any major problems: Not really. Starter, fuel pump finally at 180000, clutch slave cyl. at about 85000. That's it. Runs great.
i2i is offline   Reply With Quote
Old 02-15-2006, 05:37 PM   #57
h1machiii
1998
3.5L
113k
No major problems. Have to replace both front wheel bearings soon and left tie rod end but otherwise great vehicle.
h1machiii is offline   Reply With Quote
Old 03-21-2006, 06:56 AM   #58
trooper dude
98 trooper 94000 miles, having problem with OBDll Code 0440
failed Virginia state inspection
I've been clearing check engin light with cheap OBD scanner
Cleaned EGR
Gas cap passed state inspection
looking for info on next step
Mechanic claims codes remain on PCM even after clearing
trooper dude is offline   Reply With Quote
Old 03-27-2006, 11:46 PM   #59
Kingler5
Year:1993 Trooper
Engine:3.2SOHC 5speed
Mileage:155,000
Any major problems:None. Just routine stuff, timing belt most recently.
Kingler5 is offline   Reply With Quote
Old 03-30-2006, 11:07 AM   #60
metomwhou
Year: 1999 Trooper S
Engine: 3.5L
Mileage: 73k
Any major problems: Bought it used but untitled in 2000 with only 8k miles on it. Ex was hit pretty hard on the driverside front by a drunkard in 2002. $13k worth of damage and the insurance still didn't total it so I kept it. Fought with the repair shop to get everything just right until I deployed to Bosnia in 2003. Still pulls to the left when you let go of the wheel and the hood is misaligned so that the hood sensor isn't activated unless you jam something in there(currently a small ball of duct tape) and the rear door on that side won't open sometimes because the lock won't pop up all the way(didn't open for over two years, then one day I just pulled up on the lock and bingo, I have a 4door truck again It sat under pine tree's for almost three years so you can imagine the paint. The windshield is cracked on the top corner on the drivers side, from the inside!! How'd that happen??
I think its starting to burn oil, or either i just noticed it and I just had to top off the brake fluid. I'm glad I got it here, it needs some TLC and hopefully I can give what it needs, I really do like the thing!!
metomwhou is offline   Reply With Quote
