Go Back   Automotive Forums .com Car Chat > Toyota > Solara
Old 05-24-2018, 11:15 PM   #1
limeyguru
2000 Solara center brake light
2000 Toyota Solara center brake light not working (both side stop lights work OK) - I checked the LED light module & it is working OK. What is the most likely cause?
limeyguru is offline   Reply With Quote
Old 05-25-2018, 10:49 AM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: 2000 Solara center brake light
Are you getting voltage to the light when you press on the brake? If not, trace the wire back to the brake pedal switch and find the cause.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
The Following User Says Thank You to Brian R. For This Useful Post:
limeyguru (05-25-2018)
Old 05-25-2018, 04:33 PM   #3
limeyguru
Thanks Brian. Do you know for sure that the center brake light is fed directly from the pedal switch? The other lights are obviously not because of their multiple functions (brake, turn signal, hazard warning). I was hoping someone might have specific knowledge of the wiring to point me in the right direction so I don't have to tear open the car unnecessarily.
Old 05-25-2018, 06:10 PM   #4
Brian R.
Resident Chemist
Brian R.'s Avatar
Since it is supposed to light up when the pedal is pressed, it must get voltage when the pedal is pressed. First thing to test. There may not be a direct circuit to the light, but whatever the circuit, the connector which plugs into the light circuit must get voltage or something is wrong. At the other end of the circuit, the pedal switch must trigger the current which activates the light, whether it has a direct circuit or not.
See the following link for a service manual
https://drive.google.com/open?id=0Bx...k9VYXJ5REM5ZUk
Old 05-26-2018, 11:51 PM   #5
limeyguru
Brian, many thanks for the manual link - it really helped me to locate the problem. I found a damaged wire in the lighting harness - looked like it was ripped off by a sharp object but I don't know how that would happen as it was protected behind the trunk side trim panel which has never been disturbed as far as I know. Spliced the wire & now the lamp works OK.
