03-19-2012, 01:09 AM | #1 | |
Mass Air SensoR
Morning
What are the symptoms of you mass air sensor failing? or When do you know when it is time to have your MAS replaced? |
03-21-2012, 02:11 PM | #2 | |
Re: Mass Air SensoR
they really don't go bad very often. what is the problem your car is having?
www.groundzeroperformance.com www.3swarehouse.com 1991 Stealth R/T Twin Turbo... sitting... 1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting! 1995 3000GT Spyder SL... being modified... |
03-22-2012, 01:21 AM | #3 | |
Re: Mass Air SensoR
when you have a 1996+ model, it should set off a OBD II code...
sometimes your vehicle may go into "limp mode" http://www.obd-codes.com/p0100 what that website didn't mention is when some people use those re-cleanable filters and re-oil it too much, then the excess coats the wire in the MAFs & you'll need to clean it with an electrical cleaner |
03-23-2012, 10:58 PM | #4 | |
Your worst nightmare
Re: Mass Air SensoR
Even pre 96 cars can get an CEL from a faulty MAS and not all faulty MAS cause a CEL.
