Go Back   Automotive Forums .com Car Chat > Chevrolet > Aveo
Old 04-03-2013, 07:56 PM   #1
clarkjd3
After Head swap I have a Electrical connector I can not locate the home to
My wife has an 07 Aveo that needed a head gasket replaced. I did the work myself and the car is back up and running. The problem is now I have a connector left unplugged and can not locate where it goes. (see attached picture)
I also now am getting a flashing hold light on the dash locking the car into limp mode. I do not know if they issues are related but I at this point I am going to assume they are as I did not have the issue before.
Can anyone help me locate where this wire goes? (again please see picture)
Once I find the home I will try to clear the hold light myself or take it to a dealer/mechanic to remove the code.
The Wire in question it a 2 wire/prong light brown and brown. with a black plastic connector/ blue rubber gasket.
clarkjd3 is offline   Reply With Quote
Old 04-03-2013, 08:00 PM   #2
clarkjd3
Re: After Head swap I have a Electrical connector I can not locate the home to
I also might want to add that the picture is taken directly under the car looking up at the backside of the intake manafold/plenum. Bottom of the picture is the front of the vehicle and the connector in question is in the same loom as the alternator, (It does not go to the alternator.) and 1 wire connector i think is a temp or knock sensor.
Thanks in advance
Old 04-04-2013, 01:17 PM   #3
rkvons
rkvons's Avatar
Engine coolant sensor, in the head? Number 21 in the picture.
rkvons is offline   Reply With Quote
Old 01-20-2014, 04:08 PM   #4
djmarch
Yea...Good luck on getting to it....I mean how do you access that side of the engine right next to the firewall ? From underneath ?
djmarch is offline   Reply With Quote
