Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 01-18-2016, 01:39 PM   #1
Rayman54
ZX2 Transmission
I have a 2002 ZX2 Escort Automatic and after driving it one morning, that night it wouldn't go after putting it in gear, all that happened was the rpm would go up than after a lil bit the car wouldn't move. I Noticed fluid all over the ground and didn't think nothing of it, anyway can someone advise me what to do?
Rayman54 is offline   Reply With Quote
Old 01-19-2016, 06:38 AM   #2
MikeCStig
Re: ZX2 Transmission
Fluid all over the ground is a pretty serious issue. Now, at the very least, your transmission has a low fluid level which can cause problems on its own. The fluid leak could be a symptom of something even more serious. You'll have to find a transmission specialist for this one. It might be something easy like a blown gasket or seal, or you may need to rebuild or replace the transmission which could get more expensive than a 2002 escort ZX2 is even worth.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
The Following User Says Thank You to MikeCStig For This Useful Post:
Rayman54 (01-21-2016)
Old 01-31-2016, 06:09 PM   #3
Rayman54
jI just got car back from mechanic they found hole in transmission pan previous owner replaced transmission with one from junk yard. the mechanic repaired hole and replaced trans. filter and filled with fluid transmission is slipping badly going from first to secnd this is automatic transmission. What could be causing this, could it be the flywheel, please advise. Raylin
Old 02-01-2016, 01:31 AM   #4
MikeCStig
Well, if it's still doing the same thing after fluid is topped off and the leak is fixed, it could be the torque converter, but it's more likely An internal problem in the transmission itself.
Old 02-08-2016, 07:36 PM   #5
denisond3
It might be that the solenoid that controls the 'line pressure' in the transmission has hung up or is clogged. The result would be that the transmission wont get the proper pressure for shifting and staying in gear - and would slip as a result. Figuring out whether its getting the right pressure may be possible, using the pressure fitting on the front of the transmission, which has a raised "L" molded on the case next to it. You would still need someone who would know what the correct pressure checking procedure would be; I dont know this.
denisond3 is offline   Reply With Quote
