Go Back   Automotive Forums .com Car Chat > Car Audio
Old 01-10-2005, 02:40 PM   #16
bumpinstang77
bumpinstang77's Avatar
Send a message via AIM to bumpinstang77
Re: 2400w x 2 @1ohm???
Schemo your wrong. 1 ohm stable amps are usually class D which mean they have a different way of making the power and a lot of class d's running at 1 ohm are working under less stress then a class a/b amp bridged at 4 ohms. And class D amps usually run very cool at 1 ohm most class a/b amps running at minimum impedance get VERY hot. Blowing your speakers has nothing to do with what impedance theyre running at. 1000 watts at 4 ohms and 1000 watts at 1 ohm is the same thing. So go esearch before you post and give the wrong info to people.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
bumpinstang77 is offline   Reply With Quote
Old 01-10-2005, 06:34 PM   #17
sr20de4evr
sr20de4evr's Avatar
Originally Posted by schemo
any amp working at 1ohm is working for times as harder than it would be at 4ohms. touch an amp working at 1000watts compared to an amp at 4ohms pushing the same power. which one feels hotter? 1ohm draws and comsumes alot more power than 4ohms.
and more power always equals to more heat and distortion (at higher levels).
all that would be needed is one low wave hard wave and you can easily burn out a voice coil, like you said speakers in your previous post the subs are warrantied, but not against abusive actions.
just my input from experience, by all means i am no engineer.
yes an amp that is running at 1ohm is working 4 times as hard as when it's running at 4ohm, but a 1ohm stable amp running at 1ohm is working just as hard as a 4ohm stable amp (such as a bridged 2ch) running at 4ohm. In either case you're running the amp at its minimum impedance, and assuming similar design and build quality, you can expect the same amount of distortion and reliability from either. And as bumpin pointed out, due to the lower efficiency of the class ab 2ch (assuming it is a class ab and the 1ohm amp is a class d, which is normally the case), it will actually run hotter and suck more power from the electrical system than the 1ohm amp.
As for the subs, speakers can only blow 2 ways, thermally and mechanically, both of which are directly related to the current running through the coil. More current means more motor force which means the cone moves farther, and more current means more heat buildup in the coil. You have to treat the 2 coils independently, since they are in fact, independent coils doing their own thing. If you have a dual 2ohm sub wired in series to 4ohm that's receiving 1000 watts, you will have 15.8 amps (P=I^2*R) running out of the amp, through the first coil, and then through the second coil, and then back to the amp, so each coil will have 15.8 amps running through it. If you have the same sub wired in parallel to 1ohm and is receiving 1000 watts from some different amp, you will have 31.6 amps running out of the amp, which is then split, half of which (15.8 amps) goes through each coil, so you still have 15.8 amps running through each coil. The sub will behave the exact same way in both wiring schemes, both thermally and mechanically, the only difference is how the amp is affected. And as was said above, if you have an amp running at its minimum impedance it will have similar distortion and heat buildup as any other amp of similar build quality and typology running at its minimum impedance, regardless of what that impedance actually is.
And there are a ton of VERY high end amps that are 1ohm stable: helix, brax, dls, genesis, us amps, zapco, arc, linear power....should I go on?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
sr20de4evr is offline   Reply With Quote
Old 01-10-2005, 07:13 PM   #18
bumpinstang77
OOOOK mr technical but yea what he said NOOB
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-10-2005, 08:00 PM   #19
Dreamspawn
Dreamspawn's Avatar
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
This is getting interesting ne way my budget is around 350$tops so let the suggestions begin. Once again the speakers say 1100rms a piece at 1ohm. So let the amp suggestions begin.
Dreamspawn is offline   Reply With Quote
Old 01-10-2005, 08:26 PM   #20
sr20de4evr
sr20de4evr's Avatar
hifonics brutus 1500d or 1800d
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-10-2005, 08:55 PM   #21
bumpinstang77
ED nine.1
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-11-2005, 12:03 AM   #22
Mannyb18b
Mannyb18b's Avatar
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
I second the nine.1
Mannyb18b is offline   Reply With Quote
Old 01-11-2005, 12:11 AM   #23
Dreamspawn
Dreamspawn's Avatar
ne body have a link for it i looked on google for ED nine .1 but i can't find ne place selling them.
Old 01-11-2005, 01:02 AM   #24
Picquerist
Send a message via AIM to Picquerist
power acoustik a3000d
Picquerist is offline   Reply With Quote
Old 01-11-2005, 01:42 AM   #25
Dreamspawn
Dreamspawn's Avatar
holy Sh*t thats alot of watts
Old 01-11-2005, 02:58 AM   #26
bumpinstang77
www.edesignaudio.com It will definately put out more then a bx1500d and prolly pretty close to a bx1800d
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-11-2005, 03:20 AM   #27
schemo
mannyb18b, first off according to your age that's listed on your profile, i have 10 years of worth of life and experience than you. so please don't be so prompt to say don't listen to a newbie. just because i have less posts than you and signed up after Jun 2004 doesn't mean i don't know what i'm talking about. i was messing with this stuff while you were still in diapers, and as i stated in my post i was speaking by experience. also i wasn't arguing with sr20. he asked a Q and i responding with an anwser. i personally thinks he knows quite a bit. we were both helping Dreamspawn come to a decision. (maybe i delt with ancient technology)
if you can why don't you list some decent 1ohm amps here for him? and when i mean decent i mean that pushes out a constant amount of power, not something that jumps like a frog? i'm sure that will help him out quite a bit. as for me i would go with a punch from rockford fosgate. although those amps are in the higher cost bracket. like i said in my post.....you won't find to many 1ohm amps out there that are really good, in my opinion (i see that sr20 list a couple)
Dreamspawn, take your advice how you want it and go from there. if you need further assistance just pm me. i'll help you out to the best that i can.
Schemo
schemo is offline   Reply With Quote
Old 01-11-2005, 01:45 PM   #28
Dreamspawn
Dreamspawn's Avatar
what bout the power acoustik a2400 the ed nine is nice but only puts out 1200 watts and i want to atleast put a 1000 to each. The most powerful punch i could find was 800w. Nemore suggestions? U think if emailed SPL maybe they could throw some suggestion? I know its highly unlikley but worth a try?
Old 01-11-2005, 01:52 PM   #29
Dreamspawn
Dreamspawn's Avatar
Old 01-11-2005, 01:53 PM   #30
Mannyb18b
Mannyb18b's Avatar
Ok, im not even gunna start.
To DreamSpawn- The eD nine.1 is more like 1400 watts, real true power. The nine.1 is a pure quality amp and is UNDER RATED, unlike Rockford Fosbreaks that are overrated. Some rockford fosgate amps are pretty good ill admit that, but thats about all that can be said about them. Nine.1 rapes the Rockfords, period. And Schemo, what system do u have in your car???
