Go Back   Automotive Forums .com Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 09-10-2007, 05:31 PM   #61
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: The Ultimate Question!
yes, two way = coaxial and three way = triaxial ..... that means the mid and tweet(s) are all in the same speaker frame.
You have lots of choices when it comes to speakers, unfortunately my suggestions would be out of your price range.
PaulD is offline   Reply With Quote
Old 09-10-2007, 07:04 PM   #62
BikerPaintballdude
O.k. well do you know any decent speakers that i could probv afford(this is prob gunna be in a year after i get my subs) and how much money do you think it would cost to replace everything?
BikerPaintballdude is offline   Reply With Quote
Old 09-11-2007, 12:47 AM   #63
pimprolla112
pimprolla112's Avatar
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
This was posted by diceman in the newbie info thread a good starting point fo rinfo
This is a write-up I did on SiN for a guy that had a budget of $1000. NG thought it was pretty good, so I thought I'd post it here.
Front: (~ $170 - $250)
You want something really nice, usually a 6.5" component set. If you can fiberglass or build some kick panels, or mount them in the doors on an MDF baffle, it's better than sticking them in the stock mounts. You should also look for a really good crossover (either active or passive --- active gives you much more control, but requires more amps). Brands to look for are CDT (Don at Island Sound (islandsound1@yahoo.com) has some really good deals, look for the EF series), Resonent Engineering (for both components and subs... the XXX line are some of the best out there - you'll have to call for prices), or Focal.
Rear: ($60)
Some inexpensive 6.5" coaxials will do the trick. Pioneer, CDT, whatever. NOT Audiospawn (=audiobaun).
Amp(s): (~ $200 - $400)
You got some choices here. First of all, you really won't be happy with the sound coming from your components unless you amp them. You can either buy seperate amps for sub and speakers, which many people do because of the bling in your trunk (I mean, 2 or 3 amps does look pretty impressive), or a single 5 or 6 channel amp that powers everything. I don't think an active crossover is in your price range just yet, so I won't worry about it for now. I've got a DEI 1100d5 5 channel amp, that puts out around 1100 watts, ~ 75 on 4 channels for the speakers, and 600 at 1 ohm for the sub. I'm not touting Directed, I'm just going to try it out. Hifonics makes some really good amps, PPI is a good brand, Pheonix Gold amps are really good, and Profile makes some nice ones for the money. Depends on how much power you want.
Sub(s) ($200 - $400)
Again, you've got more options, depending on the kind of output you want. I'm not the expert on this, but I'll do my best. I'll save the enclosure suggestions for the next topic. If you want SPL (just getting loud), go for some Audiobauns... they're gonna sound like crap, but definately be loud. If you want SQ, You can do multiple smaller subs, or a good large sub. Brands to go for are RE (the SE and SX series are good for SQ, the XXX is good for SQL, and the MTs are SPL), Ascendant Audio (Atlas = $150ish, Avalanche = ~$350 both mostly SQ, with the Ava being more SQL), Incriminator Audio (get very loud, ask NGSM13 for a dealer's contact info), and Adire Audio (Brahmas are reputed to be some of the best SQ subs out there, and their other lines are very good as well). Sorry if I missed any, or got info wrong, but I'm pretty sure it's right.
Enclosure: (~$50)
You're probably best off to build it yourself. Most people on the forum here can design one for you for 10 bucks, or you can get a program like BassBox 6 Pro and come up with a design yourself. Buy the 3/4" MDF at Home Depot (or where ever), some wood glue, some silicone or thicker consistancy glue for sealing it (and the carpet), carpetting (walmart - $7 a roll, in the auto section, near floor mats), and a plate connector (for getting wires into the enclosure).
There's always been debates about whether to go sealed or ported, and most decide to go ported, because they like the extra output in the lower frequencies. I'm sure you can find all sorts of debates on this forum and others on the net about this issue. Sealed is probably a good one to start with, because it's easier to do, and harder to fry your sub with. For a 15 inch sub, you'll probably need around 2.5 cubes - 3.5 cubes (cube = cubic foot, aka ft^3). For ported you'll need around 4 cubes to 6 cubes. A 12" sub needs around 3 cubes ported, and a 10 can live with 2.5 cubes.
Wiring: ($30 to $50)
You don't have to do anything fancy here. If you're under 1000 watts, you'll probably just need 4 gauge wire for power, and 12-14 gauge wire for the speakers. Knu Konceptz has some really good deals on twisted pair RCA cables that work wonderfully, and are really fairly cheap. Ebay is a good place to get wire kits as well.
Electrical Upgrades: (~$250)
I don't have much experience here, because my car came with a pretty decent setup. Ok, what I've learned so far is that most people upgrade the big three wires first (the power and ground wires between the alternator and the battery, and the ground to the chassis and the ground to the engine block), then replace the battery (usually with an Optima Yellow Top or a deepcycle of some sort), and finally a new high output alternator. Like I said in the previous post, I don't know too much about it, but this is what people usually do.
OK, I'm sure I missed some stuff, but those are the basics. Good luck
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
pimprolla112 is offline   Reply With Quote
Old 09-25-2007, 02:34 PM   #64
Jeppe
Jeppe's Avatar
Send a message via Yahoo to Jeppe
spend more on the amp and less on the subs
-Stinger - Pioneer - Memphis - Sundown - DD-
Jeppe is offline   Reply With Quote
