12-18-2003, 02:31 PM | #1 | |
2003 Tacoma disable daytime running lights
Is there a way to turn off the Daytime Runing Lights?
12-18-2003, 04:55 PM | #2 | |
nope
12-18-2003, 09:19 PM | #3 | |
find the wire and cut it
12-18-2003, 09:19 PM | #4 | |
Re: 2003 Tacoma disable daytime running lights
the add a switch on the inside of the truck
12-29-2003, 06:24 PM | #5 | |
Locate the DRL relay (between gas pedal and stereo on mine), cut the wire to pin #2. You can add a switch in this wire if you want to turn them on and off.
01-12-2004, 12:57 PM | #6 | ||
Re: Re: 2003 Tacoma disable daytime running lights
would need more info to complete it successfully - never mind I found it http://www.yotatech.com/~corey/tech/ducky_drl/ducky.htm Thanks TBob |
04-15-2004, 12:05 AM | #7 | |
yes there is a way, dont cut the wires! under the hood
in the fuse box, pull the fuse marked DRL-"daytime running lights" it should be a 7.5, let me know if this helped you. It disabled mine on a 99 tacoma. |
