Go Back   Automotive Forums .com Car Chat > Car Audio
Old 01-31-2005, 06:27 PM   #46
bumpinstang77
bumpinstang77's Avatar
Send a message via AIM to bumpinstang77
Re: Subwoofer Setup
nope they're just always SLAMMED with buisness give them a call ....... (702)896-4823 you might hafta try a few times but you'll get ahold of them.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
bumpinstang77 is offline   Reply With Quote
Old 01-31-2005, 06:43 PM   #47
ponchonutty
ponchonutty's Avatar
Re: Re: Subwoofer Setup
Originally Posted by Powerefx
Did Re audio run out of businees or sumthing?
First of their site is not updated, and secondly they havent answered on of like 5 emails i sent them.
No, it's just a very small company. They are not massed produced items. They are pretty much hand made.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
ponchonutty is offline   Reply With Quote
Old 01-31-2005, 06:46 PM   #48
bumpinstang77
Re: Subwoofer Setup
Destijl :-D
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 01-31-2005, 10:43 PM   #49
Powerefx
Re: Subwoofer Setup
Is it alirght to use vinyl on the box instead of carpet? I was thinking of putting some kind of thin spunge/foam like material between the box and vinyl? WIl this interfer with the quality of the sub? Also if i put thoe neon rings around the sub, will that mess up the sound too?
Powerefx is offline   Reply With Quote
Old 02-01-2005, 06:44 AM   #50
ponchonutty
Nope. I suggest getting vinyl that already has the foam attached to it. If not, you'll be fighting it big time. Neons, they are ok but sometimes the cheaper ones can create a lot of RF noise that your amps may pick up and run through your speakers.
Pioneer 4900mp
Orion C63 Coax rear
Old 02-01-2005, 07:58 AM   #51
bumpinstang77
Re: Subwoofer Setup
Vinyl is a lot harder to do then carpet so be ready to take your time and be good at it.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-01-2005, 09:14 AM   #52
Powerefx
Re: Subwoofer Setup
Thats what i thought, Time consuming Yes, but hard, nothings hard if u know how to do it. Anwayz another question, Should i use silicone or woodglue in the boc, adn should i use any kind of specific terminals?
Old 02-01-2005, 09:34 AM   #53
bumpinstang77
Re: Subwoofer Setup
I use wood glue between the joints when screwing together then liquid nails or silicone on the inside of the box along the joints... overkill....yea....but its sealed good. I don't use terminals unless requested to I usually just drill a small hole then pull the speaker wires through and seal the hole.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-01-2005, 03:43 PM   #54
CBFryman
Banned
CBFryman's Avatar
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Subwoofer Setup
Personally i have installed one single tempest set up and 2 dual tempest set up and my tepest for my room is SAPPOSED to be here this weekend, damn back orders. The signle set up was 4.2cuft sealed in a camry, took up the entire trunk. great SQ. 410w. i forget what amp.
both dual tempest set ups where 6cuft each tuned to 25Hz. Same exact enclsoure deisgn and all). one was in a Denali and the other in a suburban. both SLAMMED. 1000w JL in the suburban and dual 400w amps (some off the wall brand) for the denali. the suburban had far better sq but even the denali with off the wall amps had better SQ than many main stream set ups i have heard.
I have heard 2 SE set ups. one SE 12 in a 3.5 cuft ported box (not sure of the tuning, i didnt personally install it) and one with dual se 15's. the dual SE 15's had 800w each going to them and the single 12 had a JL 1000w amp on it.
Persoanlly i like the sound of the tempest by far. i know the SE is a great woofer. but i think the tempest is better for the price. both are great. i'd just like to see a little more flava' in your recomendations.
CBFryman is offline   Reply With Quote
Old 02-01-2005, 04:41 PM   #55
bumpinstang77
Re: Subwoofer Setup
3.5 cubes ported is WAY too big for an se 12 ported..... the response was prolly sloppy as hell comparitavely speaking to a smaller box..... se 12's are good from 1.8-2.25 cubes ported..... What was the SE 15's in?
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-01-2005, 04:56 PM   #56
CBFryman
Banned
CBFryman's Avatar
Re: Subwoofer Setup
Tahoe? that or the GMC version of the tahoe. the Yukon or how/ever you spell it. older modle.
Old 02-01-2005, 04:59 PM   #57
bumpinstang77
Re: Subwoofer Setup
The dual SE setup..... u didn't say which vehicle....
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-01-2005, 05:02 PM   #58
CBFryman
Banned
CBFryman's Avatar
Re: Subwoofer Setup
oh my bad, it was in an escelade at a car show like 2 summers ago in daytona.
Old 02-01-2005, 05:47 PM   #59
ponchonutty
I just use Liquid Nailz on the seems then screw it together every 2". Make sure to predrill everything. No other caulking is necessary but if you want to go ahead. Make sure that if you use something like Silicone, make sure it completely dries before putting the subs in. The vapor from it can degrade the material used in the subs. Use to have a lot of JL Audio subs fail and it only happened with my one installer. Come to find out he liked to use Silicone on the seems after everything was together like B-Stang. But really, only something like the L nails only needs to be used. We tested different ways of building them in the lab and found that was the best way.
Do you plan to vinyle more than one side of your box? If so, the easiest way is to get real thin pieces of Luon or simular stuff and cut it to match the sides of your box. Cover those with your vinyle then glue them to your box. Otherwise doing the seams so they look right is a bitch!
Pioneer 4900mp
Orion C63 Coax rear
Old 02-01-2005, 07:35 PM   #60
Powerefx
Re: Subwoofer Setup
Ya im gonna be covering all sides of the box, and what in gods name is LUON, where can i pick that up?
