Go Back   Automotive Forums .com Car Chat > Racing > Street Racing
Old 11-23-2002, 12:30 AM   #16
Cbass
Cbass's Avatar
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
If you build a good stroker smallblock, it'll make as much torque as a big block. Of course, if you build a stroker big block...
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Cbass is offline   Reply With Quote
Old 04-14-2016, 02:25 PM   #17
rvaughn61
Re: Chevy big block in a Trans Am?
I worked for gm in 1979 building, and testing the trans am and the 403 Olds engine was a small block, but the 400 was a Pontiac big block. The 403 was 185hp and 320trq. The 400 available in 79 as a TA/6.6 only with the 4sp. Was 220hp and 335trq. It did come with 3.23 gears. The stock 6.6litre cars 77 through 79 came with 2.65 gears. Unless they, (stock 6.6litre cars), were ws6 equipped cars which came with 3.08 gears. WS6 package was 4 wheel disc brakes, polyurethane bushings, larger anti roll bars, faster steering gear, and 8 inch wide honey comb wheels instead of 7 inchers, and 3.08 gears.
In 78 you could get the TA/6.6 with either transmission and was 220hp. The standard 6.6litre was 180hp. 300trq.
In 77 the TA/6.6 was 200hp, the 6.6litre was 180hp.
The highest top speed cars were the 1978 TA/6.6 litre automatic cars according to motor trend flat out they ran 133.4 mph. Our testing at the plant didn't get that high of a top speed. We only saw 130mph. From TA/6.6 cars with the auto, 126 from the TA/6.6 4spd cars (at redline), 120mph from the 6.6litre cars with the 403 engine, 118 from the 400 6.6liter cars. WS6 403 equipped cars saw 123mph.
Also from my notes I see the fastest 1979 car was the TA/6.6 running the 1/4mi. In 14.64@99.6mph. 0-60 was around 6 seconds flat. Traction was noted as a problem for timed runs.
I hope this information helps you in some way.
Randy
rvaughn61 is offline   Reply With Quote
chevy Big block into 69 GTO? pestkiller05 Classic GTO's (1964-1974) 8 06-09-2013 07:05 PM
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 09:21 AM
93 trans am runs ruff 9_trans_am_3 Firebird Discussions 3 04-14-2009 12:48 PM
600+ rwhp E36 M3 turbo vs. big block Trans am and motorbikes BTT Car Videos 1 07-04-2008 06:10 PM
3946074 Chevy Big Block Heads/ big journal 302 crank Todj74 Chevrolet Classics 1 06-08-2007 11:25 PM
