| Latest | 0 Rplys |
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version. |
11-25-2006, 10:11 PM | #16 | |
Re: Instant Complete loss of power b2000 86
So, I got a chance to check things out. I checked the neck to the air filter assembley and all was clear. I disconnected the right most hose leading into the reed assembley and put the cover on, it worked! What does that hose do and how do I fix it? I drove the truck with the air cover on and the hose disconnected and it ran fine. I just wonder if I will pull dust and small particles into the carb with the hose disconnected.
Any thoughts? Thanks in advance. |
11-25-2006, 10:20 PM | #17 | ||
11-25-2006, 10:34 PM | #18 | ||
I did plug it with my hand when I had the cover on and there was no effect, it seems that the hose was blowing into the air assembley but I can't find anything on what it does exactly. So in response, I would say that nothing is blocked but the hose or valve that is involved in that connection is not functioning properly. Someone lead me to believe that these three hoses work in conjunction with the exhaust by pulling clean air into the exhaust system somehow. |
11-25-2006, 10:47 PM | #19 | ||
11-26-2006, 07:21 AM | #20 | |
What I suspect the true problem is (and I am not going to like) that the CAT is blocked and pushing exhaust back through the pipe/hose into the air intake. When I disconnected the hose it stopped the exhaust from getting into the air filter area. What doesn't make sense is that the engine should still run like garbage with all the back pressure but I am not exactly sure I understand the dual CAT system on these trucks.
11-26-2006, 04:04 PM | #21 | |
I think that was one of my posts-i.e. the cat was plugged-and I think u r correct.The first cat(called a pre-cat) is right under the exhaust manifold and covered by that cheesy bit of tin heat shield.The second one is right under the drivers feet and i bet that is the one that is plugged up.Replace it with a magnaflow hi-flow cat(about 45 bucks) and see if that doesnt cure ur ills.If the cat is plugged ,it does cause an increase in the back pressure which will eventually burn ur exhaust valves and then the engine goes.Since when u unplug the hose to the reed valve assembly,that causes a drop in back pressure and the truck runs better.To give u an example,my truck would not run over 75 mph.I changed the cat out,tuned it up and it now is able to do 95-100 mph.Makes a difference. BJ
11-28-2006, 08:47 AM | #22 | |
Thanks for the advice, hopefully you weren't too put off that I disgarded your idea of the CAT but I really didnt want to deal with the exhaust in the northeast this time of year. With that said, I suspect that it is the second CAT causing the issue as the 2 right most reed valves hit the exhaust between the two CAT's.
I really appreciate everyone's input and thank all of you. I will post when I replace the CAT and the outcome. Could you post the best vendor of the CAT you suggested for purchase please? Thanks again. |
01-26-2007, 09:24 AM | #23 | |
As an update, I changed the rear CAT on my truck and it now runs normal. Thank you for all the help.
01-26-2007, 01:04 PM | #24 | |
Great to hear that ur ride is back to normal.Be careful out there.BJ
01-26-2007, 01:38 PM | #25 | |
Glad you fixed it And thanks for posting back
Thread Tools | |
