12-08-2018, 01:48 PM | #16 | |
AF - Advisor
Re: Lack of fuel pressure
Buy a about 4 feet of grease gun line extensions & fittings, a needle valve and a 0-30psi pressure gauge. Seal the connections with permatex non-hardening sealer then start yer pump.
Here's my cheapo getup, Greasegun extension leaving the Vulcan fitting tapped for the guage. Needle valve for damping pressure pulses to calm the gauge needle. https://www.acehardware.com/departme...valves/4506572 It ain't pretty but this dog hunts and he don't leak. The whole contraption using the fuel pressure check kit to screw onto the port on the injector pump and later I added needle valve to dampen the pressure pulses.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. Last edited by Chris Stewart; 12-08-2018 at 03:23 PM. |
12-10-2018, 04:24 PM | #17 | |
Awesome thank you. It will be a bit before I have time to do it but I'm sure it will be well worth the time and effort.
12-17-2018, 08:12 PM | #18 | |
This has nothing to do with what we were talking about, but my last exhuast hanger finally rusted through and I was dragging my exhuast down the road. I cut off all the rusted pieces between the cat and muffler. I want to put on a deep note muffler and dont know which to buy. Should I take the cat off then put the new muffler there or after the cat. I dont want a super loud exhuast but I want the deepest note possible. Thoughts?
12-18-2018, 06:37 PM | #19 | |
AF - Advisor
The 2000 Dodge Ram w/Cummins Diesel did not come with a catalytic converter as far as I know. You might have a muffler and resonator on your exhaust.
I don't know how to deepen the exhaust tone....sorry pal.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
01-09-2019, 10:18 PM | #20 | |
Your right it ended up being a resonator. Looked like a cat till I started looking more closely. That poor old pickup finally gave out. It did good with the new lift pump till I pulled my trailer with 5 cows. Did great till I got to a hill then lost all power and died. Had to get a tow, mechanic said total rebuild to get the poor old thing going again. Ended up trading it for a 08 Cummins. It was a sad day. But I have to say that 6.7 is insane. Hope they're as reliable as that old 5.9 was.
01-10-2019, 08:50 PM | #21 | |
AF - Advisor
Yup, I understand the 6.7's are torque monsters.
