| Latest | 0 Rplys |
WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
Thread Tools | Search this Thread |
#406 | |
Re: Lola T-70 Mk III
I'm not sure if I figured it our yet... but is that the rear view mirror? It looks cool, but alien as well
#407 | |
Yes, it's a Wink mirror. This is a three panel, I use the five panel versions in my real cars.
#408 | |
I machined these knobs to mount the Wink mirror to the brackets.
#409 | |
FWIW, today is the three year anniversary of when I started this project.
I designed and 3D printed a license plate for it; even started painting it, but I didn't care for the way it looked mostly because it was too thick and had no back side detail. So I made another one from scratch. I've used similar processes to this to make other plates. I started with some 0.005 sheet brass. I cut this blank and drilled some holes. ![]() And then I cut a plastic "rim" from .005 sheet plastic and attached it with clear gloss paint. ![]() |
#410 | |
The same plastic was used to make the "raised" face with dropouts for the tags. All the tiny letters for the state and the main characters are individual pieces. There are two layers for the larger ones. They were arranged by hand with a scalpel and tweezers and held in place with clear gloss. (That's 25 pieces.)
That "assembly" was applied as a single piece to the brass. I know it looks a bit rough, but once I add the fillets to the letters and numbers it will look better. ![]() |
#411 | |
Well respect for even managing this result. Indeed it looks a bit rough, I'm curious how it will look in the end.
#412 | |
The backside was done with 11 more "backwards" pieces and drop-outs to create the stamped effect. It will be silver so I started building the color up in light coats to help hold the pieces in place.
![]() Now that the characters have had the fillets added to them and a coat of primer, they are starting look presentable. ![]() |
#413 | |
The first color for the face was applied…
#414 | |
The license holder is made of brass too. I had to anneal it to get it to conform to the tight U-channel shape for the bottom section.
#415 | |
I made the license plate light housing and added it to the holder.
![]() ![]() Just loosely assembled… ![]() |
#416 | |
And the black is done... (I drilled the mounting holes through the plastic first.)
The top one is the one piece 3D printed plate; below it is the new, more in scale, (37 piece) one. Maybe only a subtle difference, but worth the effort to me. ![]() A thin coat of clear and it's done. I'll add tags closer to the end of the whole project. ![]() |
#417 | |
That is stunning. I'm out of words.
#418 | |
Thank You!
I made gaskets for the water pump and installed it for the last time. I made the belts from sheet styrene cut into strips then beveled into the shape of a V-belt. I semi formed them before cementing them to the pulleys. (I painted the insides and edges black first.) ![]() ![]() Careful trimming of the ends created a net fit that was filled with the cement. Then I hand painted them black. The seams are in this shot, but not visible from any angle. ![]() |
#419 | |
The (brass) winglets have been painted and the fasteners added.
Now they go in the slowly but continually growing collection of ready to install subassemblies. ![]() ![]() |
#420 | |
The rear spoiler has been painted too. Two pieces of sheet brass soldered together.
![]() Yes it has a clear Lexan section in the middle. ![]() |
