| Latest | 0 Rplys |
04-05-2005, 02:03 PM | #16 | |
Re: Fuse Diagrams 1988 Premier
yeah dude, i have that problem too, the wipers dont work, but squirts fluid.
04-05-2005, 03:30 PM | #17 | |
hey Knifeblade, do you have AIM or Yahoo or MSN or somethin' like that? 'cause like, so far you've been my "car-god" haha, fuckin', if you think i could hit you up, tha'd be great.
04-08-2005, 09:44 PM | #18 | |
Nope, thankfully, haven't had to, but my chilton's describes it, chilton manual # 20384, and it not too bad. Three bolts only, but it all Underside of ride removal. It doesn't describe how to disconnect the wiring. You will need a long extension for a bolt or two, you have to acces a bolt, maybe two from a frame or brace-hole. You may also have to figure out how to remove a heat shield. Chilton says it only a clamp, and not all Eagle's have the shield.
If ya plan on pulling, I can detail it via Chilton's a bit more, with torque spec.'s, etc. but it seems an under the car pull-out. |
04-08-2005, 09:47 PM | #19 | |
Yo, guys, feel free to email anytime at tt_48750@yahoo.com or my gmail [preferred] at tam.tt48750@gmail.com. I usually scan emials after work, so expect some lag, but I'll try to help
04-08-2005, 09:56 PM | #20 | |
Old-time trick to see if wiper motor is toast~~~~
First, ya have to pull the cover cowl, plastic screws, 3/4 turn to release, should expose motor. I f ya can see the harness, unplug it. take two wires, one each off of each battery terminal, and quickly jump the motor terminals, cross the wires to the terminals once or twice, to see if the motor runs. If the otor doesn't activate, motor is toast. WARN!!!!!! This method will likely start the motor, if it good, into full hi-speed wiper mode, so stay away from the wipers or motor as best ya can. Do NOT hold the jumpers on motor any longer that to try to trigger the motor. |
04-08-2005, 10:01 PM | #21 | |
If the wipers pump fluid out, but the wiper swith won't turn the wipers on-off, then it is the console mounted lever that is toasting. There is a back-yarder way to at least activate low speed cycle, bypassing the switch itself, but first use the above post to ensure the motor itself is still good.
04-08-2005, 10:03 PM | #22 | |
It would be useful re this issue if one of you start a new thread here,so we don't overload this thread and find it closed or unmanageable to follow.
04-09-2005, 01:42 PM | #23 | |
hah, i was out in my garage today, looking around.. found a chilton's, for the premier, apperantly my brother used it for his sundance, how fuckin' fortunate :8-)
04-12-2005, 04:54 PM | #24 | |
Jumping the battery to the motor... duh, what a great idea! As for a new thread, I'll try but this is my first time ever using chat outside of regular e-mail. Actually, when I originally found your profile, it was mixed in with TONS of other comments regarding Premiers, but I haven't found my way back there
04-13-2005, 07:26 PM | #25 | |
My new thread is going to deal with old-time tricks, so check it out, I'll start posting more back-yarder stuff soon.
Tam |
Thread Tools | |
