Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-28-2011, 06:41 PM   #1
blazer king
Send a message via Yahoo to blazer king
heater blower problems
I got a 95 suburban and when I first got it the heater blower only worked on high and low but now it just works on high. at times i'll have to tap it to get it started. Is this the fan or a switch?
blazer king is offline   Reply With Quote
Old 11-28-2011, 06:58 PM   #2
j cAT
Re: heater blower problems
check the resistor/connections to the blower motor.
trace down voltage loss or if voltage at motor and it is not running at the lower speeds the blower motor may be defective where it now requires high speed voltage to operate.
Old 11-30-2011, 11:27 AM   #3
blazer king
I got a new blower but it still runs only on high. I got a resistor but havent installed it yet. Where is it located???
Old 11-30-2011, 11:49 AM   #4
gmtech1
gmtech1's Avatar
Looks like it's on top of the hvac housing behind the glove box. Glove box will have to come out.
gmtech1 is offline   Reply With Quote
Old 11-30-2011, 02:47 PM   #5
j cAT
should be near the blower motor.
Old 11-30-2011, 05:52 PM   #6
777stickman
This is correct. The resistor pack has 4 wires. However, before you change that out you should check for voltage from the switch to the resistor pack. You weren't clear on what it was that you had to tap on to get the blower to work somewhat.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Heater blower? problems superpsychocow Bonneville 16 02-10-2007 04:31 PM
Newbie Here- with a heater blower problem aharbormoon Bravada 6 04-08-2005 02:34 PM
1999 Malibu heater blower problems PhoenixSandman Malibu 2 10-12-2004 06:41 AM
Headlight/AC Heater Blower Problems PrixGT Grand Prix 1 10-05-2004 09:49 AM
Heater Blower Problem on 328 christopher salata 3 Series 11 03-23-2004 07:40 PM
