07-16-2014, 12:06 PM | #1 | |
Only runs with foot on the gas pedal?
Have a 06 Grand Caravan 3.8L that suddenly quit and would start back up easily enough, but one had to keep foot on the gas to keep it going.
I pulled two codes: P0123-throttle postion sensor 1 high P0508-IAC valve sensor circuit low/undercurrent So far I have removed the IAC and cleaned it with throttle body cleaner, cleaned throttle body out as well with the spray, installed new EGR since it got mangled trying to remove it for cleaning. Removed the TPS connector and with key on, took measurements and I am getting a reference voltage proper ( almost 5 volts). I then back probed the connector once it was plugged back in and again things checked out, the reference lead was varying between .7 and 4.7 volts as I manually moved the throttle plate. I had switched out the IAC with a used one, from an engine that had been running before being parked, but it made no change. Note: I have a new TPS but am holding off on changing it until I investigate whether or not it may have a clogged fuel filter causing it to stall at idle speed. Now if can just locate where it is..the sketchy diagrams in my Alldata program are of little help.
2002 Dodge Dakota 4x4 3.9L Last edited by Black_Blade; 07-16-2014 at 08:42 PM. |
07-17-2014, 07:35 AM | #2 | |
Re: Only runs with foot on the gas pedal?
Is the fuel filter inside the fuel tank on these models?
2002 Dodge Dakota 4x4 3.9L |
07-18-2014, 06:15 AM | #3 | |
"adjusted the idle screw" was the note left for me this morning and it has apparently fixed this problem. I had left a message for an retired mechanic I knew, and he had came in and looked at it last night.
I wasn't aware there was an idle adjustment screw anywhere...that idle was taken care of by the computer via IAC etc...
07-18-2014, 11:36 PM | #4 | |
AF -Advisor
Wasn't aware of it either. What RPM is it idling at now? Does it maintain idle when you turn on the A/C?
BTW - Won't be the pump. It spins at the same RPM whether the pedal is floored or at idle because it gets the same 12vdc all the time. No filter on an 06. Just the inlet sock on the pump.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
07-31-2014, 02:17 PM | #5 | ||
