| Latest | 0 Rplys |
07-31-2015, 10:18 AM | #1 | |
wheel covers
I just purchased a set of wheel covers for a 2008 crown vic they don't seem to be on tight is ther a special lug nut for them any help will be welcomed
07-31-2015, 01:24 PM | #2 | |
Confoundingly Lucid
Re: wheel covers
They do require a special lugnut; this is the same lugnut that is used with the pancake type hub caps. Standard lugnuts will not work.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
The Following User Says Thank You to silicon212 For This Useful Post: |
kennywhit (07-31-2015)
07-31-2015, 01:58 PM | #3 | |
Re: wheel covers
the set I got was a cheap set I have the pancakes on it now but I have a set of 10 spoke now are ther the same lug nuts or the wheel cover is the problem u have a pic of the lug nuts for them thanks very much
07-31-2015, 09:46 PM | #4 | |
Confoundingly Lucid
Re: wheel covers
If they're aftermarket wheels, than anything could be up. The wheel covers I was referring to were the factory 17" style full wheel covers.
Do you have a picture of the back side of the wheel cover?
08-14-2015, 02:01 PM | #5 | |
Re: wheel covers
they are plastic
