Go Back   Automotive Forums .com Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Thread Tools Search this Thread
Old 06-07-2012, 07:42 AM   #1
ellev8or
67 Pontiac Bonneville-Part Replacements
Bonneville Specs:
Engine: 6.6L, 400 CID, V8, w/AC
Transmission: Uncertain
Mileage: 58,000
I'm currently replacing new parts; radiator, intake manifold, and new carburetor. I'm almost done but ran into a problem trying to locate where this one vacuum line connects to.
On the stock carb there was a long metal vacuum line coming from the rear of the carb going down to the left rear of the engine (if facing the engine) and the line was not connected at the other end from the carb. I'm having difficulty with locating where this vacuum line reconnects to.
I have removed the stocked carb and replaced it with a new Edelbrock Performer carb with 600 CFM. Also, a new intake that matches the new carb. If possible, I'm trying to mimic the same set up as the stock carb. I'm not looking to burn tires but to remove that sluggish undertow drive I use to have. Better gas mileage is my goal actually but to feel the response when I hit the pedal. When I drove 50 mph it felt like 30. Any advice in this area on a V8 would be grand.
I've attached photos to give you an idea of how the old stock carb was set up. Let me know if they were not viewable.
If someone can tell me what size or speed transmission that would be helpful. I'm learning a lot of different models and make ups to this vehicle. It was hell finding the right size radiator.
Thanks for your help.
ellev8or is offline   Reply With Quote
Old 06-08-2012, 12:20 AM   #2
Oldengineer
Re: 67 Pontiac Bonneville-Part Replacements
I suspect this line is supposed to go to the transmission's vacuum modulator. Don't know for sure though - back in 67 I was playing with a Plymouth Barracuda.
Regards:
Oldengineer
Oldengineer is offline   Reply With Quote
The Following User Says Thank You to Oldengineer For This Useful Post:
ellev8or (09-10-2012)
2000 Pontiac Bonneville Keyless Remote Battery Replacement Programming Help pistons19 Bonneville 1 07-25-2009 08:13 PM
2000 Pontiac Bonneville Factory Radio Replacement With An Aftermarket Raido? vp82 Bonneville 5 06-26-2005 03:05 PM
98 Dodge Intrepid & 01 Pontiac Bonneville SSEI keyless entry programming? PSORC1 General Discussion 1 10-04-2002 10:58 PM
program new and also 2nd remote entry for pontiac bonneville tom_e37921 General Discussion 0 07-29-2002 02:33 PM
1994 Pontiac Bonneville vs. 1989 Z24 dbartoschek Street Racing 2 06-14-2002 05:38 PM
Bookmarks
Search this Thread:
