Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 11-05-2007, 04:31 PM   #16
blu3kgt
Re: how to get the fog lights on with the parking lights
I say Screw DOT standards!!!LMAO!!!! well basically we have all said this already cuz were all trying to do this mod lol
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
blu3kgt is offline   Reply With Quote
Old 11-05-2007, 06:21 PM   #17
AutostradaVR4
i'll bite my tounge, since i'm kinda gonna be part of the DOT very shortly lol
but definitely keep us posted if anyone succeeds. I say, first one to crack it gets honorable mention when and if this gets FAQ'd.
oh yea, and dont forget to keep taking pics for the write-up!
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
AutostradaVR4 is offline   Reply With Quote
Old 11-05-2007, 06:47 PM   #18
Stealthee
Your worst nightmare
Stealthee's Avatar
Ive got the SLR so I will defintely have to take pictures
Stealthee is offline   Reply With Quote
Old 11-06-2007, 08:28 AM   #19
blu3kgt
man im still trying to figure it out.... well i got it to come on with the parking lights with the foglight switch but then it wouldn't work with the regular low beams... so im still trying to figure this out.... i think in order to make them work both time you would have to add another foglight switch because the wires used to the switch when turned on and off reverse polarities, what was once ground become positive and what was power becomes ground...... so i believe adding another switch would solve that problem and one switch will control when the parking lights are on, but the other switch will control when the regular beams are on.... but im pretty sure there is a less complcated way to do this....well what i did notice is that in order to make this work i don't think we can still use the factory switch due to it setup, which the same switch is the one not allowing to do this mod...because i cut all the wires and thought of every single method possible and it would only let me do one or the other but not both so im pretty sure we would just need an after market switch..... i think i might just cut the foglights under the hood and run my own wires...
Old 11-06-2007, 08:44 AM   #20
liquidPunk
liquidPunk's Avatar
Send a message via AIM to liquidPunk
Really? Hmmm, I was thinking that there is a power wire from the fog switch (on and off) to the headlamp handls switch (on and off) then to the foglights themselves. SO you should be able to cut the wires going to and from the headlamp handle switch, connect those two wires and then the foglights should come on whenever you push the fog button in (as long as the car is on)
not so? I havent had time to look, have work till 5 and then class till 930 but tomorrow ill prob have a chance.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
liquidPunk is offline   Reply With Quote
Old 11-06-2007, 08:51 AM   #21
AutostradaVR4
i would "think" all you should have to do is find which wire in the switch connects to the low beams, cut it, and connect it instead to the parking lights.
Formerly BlinkRA182
Old 11-06-2007, 09:00 AM   #22
blu3kgt
i think i tried that but for some reason it didn't work.... i will try it and test it again...
Old 11-06-2007, 10:33 AM   #23
blu3kgt
i just tried that and it only works for one way but not both...so now i am start to think that the wiring has nothing to do with the switch.... the wiring has to be done at the fuse box... because what provides the power for the foglights is the same wire powering the low beams because they only come on if the low beams are on.....so we just need to disconnect that wire and hook it up to the low beams main power source.....or something like that
Old 11-06-2007, 03:16 PM   #24
blu3kgt
new thread
Old 11-06-2007, 08:07 PM   #25
AutostradaVR4
awesome man!
im gonna give it a go tomarrow...just one question...you;re talking about the fust box under the dash right?
Formerly BlinkRA182
Old 11-06-2007, 08:32 PM   #26
blu3kgt
no the fuse box under the hood... sorry i forgot to post that but now i edited the posting
Bookmarks
Search this Thread:
