Go Back   Automotive Forums .com Car Chat > Dodge > Ram Van
Old 04-28-2014, 11:23 AM   #1
darkiss4428
Question dodge ram van b250 wont spark
van tries to crank but has no spark at all i bought new coil and rotor button but cant get spark to distributor any ideas, also the van has eletrical problems it could be part but what would be the most likly thing if eletrical where could it be any help is better than none
darkiss4428 is offline   Reply With Quote
Old 04-28-2014, 12:14 PM   #2
alloro
Re: dodge ram van b250 wont spark
Do you have 12 volts going to the coil primary connections?
alloro is offline   Reply With Quote
Old 04-28-2014, 12:58 PM   #3
darkiss4428
i dont have a volt meter but have tried power direct from the battery with no change
Old 04-28-2014, 01:36 PM   #4
alloro
In that case, assuming it's a later model (you didn't post the year or engine) I'd go with a bad crank sensor, otherwise it's likely your PCM is fried.
Old 04-28-2014, 02:47 PM   #5
darkiss4428
sorry, its a 91 dodge ram van v8 5.2 liter
Old 04-28-2014, 02:57 PM   #6
alloro
The 1991 had a crank sensor, so yes check that out first.
Old 04-28-2014, 03:25 PM   #7
darkiss4428
how do i check the crank sensor?
Old 04-28-2014, 10:22 PM   #8
alloro
Without the proper test equipment you pretty much just replace it.
