Go Back   Automotive Forums .com Car Chat > Dodge > Ram Van
Old 08-19-2013, 12:14 AM   #1
benjaminjb
1990 b150 ram van 5.2
Low fuel pressure.
With fuel pressure reg hose off.
14psi
With fuel pressure reg hose on reads 8-9 psi. Engine slowly shuts off.
When driven with fuel pressure reg hose on or off, van runs like no power. Like a Honda 1.5 liter trying to push a van. Louzzzyy
13-14 volts to pump. Yes.green wire. Blue 6 volts
Asd tested passed. Green wire on when engine is on. Off when key forward engine not started.
Tried direct power from batt 13-14 volts running. Green wire.
Replaced fuel pressure reg
Psi. Went from 6to9 with new regulator.
Coil good. Tune up done oil change. Wires n plugs. Cap n rotor, good spark.
All that ok.
Could it be clogged throttle body. Or faulty fuel pump. Weak?
benjaminjb is offline   Reply With Quote
Old 08-23-2013, 01:54 PM   #2
jamesslcx
Re: 1990 b150 ram van 5.2
Does your van have a fuel filter in the fuel line? Sure does sound like a weak pump, with so low a fuel pressure.
jamesslcx is offline   Reply With Quote
Old 08-23-2013, 06:50 PM   #3
alloro
You're getting sufficient fuel pressure, why are you focused on the fuel pump as the culprit?
To me it sounds like a clogged catalytic converter.
alloro is offline   Reply With Quote
Old 08-23-2013, 07:34 PM   #4
benjaminjb
Yes in line. Fuel filter replaced.when I did initial tune up.
And the manual for the year van it is. Stated fuel pressure has to b @ approximately 14-15 psi with fuel pressure regulator hose connected
And it says it has to read approximately 21psi when fuel pressure regulator hose disconnected.
8-9 psi with it disconnected sounds way to low.
Can you confirm that 8-9 psi of fuel pressure for TBI is sufficient enough. And where did you get info from. Please post a link proof evidence. Or what you referred to, to say 8-9 psi is good .
Pump is getting 13-14 volts. Low pressure still. Van shut off if I connect fuel pressure regulator.
