Go Back   Automotive Forums .com Car Chat > Ford > F Series
F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750.
Old 12-13-2019, 01:26 AM   #1
ScoredRotors
1989 F-250 7.3 IDI, a few major problems
I recently bought an '89 F-250 with a 7.3 IDI. I guess I could learn from experience by just taking it apart but some kind of reference is always good. I'm pretty positive I know some of the issues for sure, but if you all could give some imput I would be thankful.
So, first off, excessive white smoke and loss of power. I'd say injectors but I haven't taken it apart yet. Next is that the fuel pump in the primary tank is completely non-functional. The tacometer stops working randomly and switching between the two fuel tanks for a few moments gets it to come back on. Absolutley no clue on that other than some faulty wiring. Brakes and tires are also needing replacement. If you guys have any advice on what parts I should go for or where to get them I'd like to hear it. I've worked on some gas engines but diesels are a little different.
ScoredRotors is offline   Reply With Quote
Old 12-13-2019, 07:49 AM   #2
CapriRacer
Re: 1989 F-250 7.3 IDI, a few major problems
WHITE smoke is likely coolant. Bluish gray smoke is likely oil. Black smoke is unburned fuel.
So it is important to know if it truly is white or perhaps a dilute bluish gray. In either case, the fixes are either expensive or time consuming. Given the age, I'll bet a complete engine rebuild is needed.
CapriRacer is offline   Reply With Quote
Old 12-27-2019, 11:29 PM   #3
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
On a diesel, white 'smoke' might also indicate unburned fuel ... if there is one or more cylinders misfiring you may see this. A cold diesel engine can smoke like this until enough heat builds up in the engine for proper combustion. Bad injectors can also cause this, as can low compression.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
Tags
7.3 , diesel , ford , idi , injectors
