Old 02-17-2019, 12:17 PM   #16
gionc
Authorized Vendor
gionc's Avatar
Re: Ferrari 312F1, Chris Amon, Monaco 1967. MFH,1/12.
Superb!!!!
gio
Old 03-10-2019, 01:13 PM   #17
pgarat
pgarat's Avatar
Hi,
Thanks for kind comments!
A last sanding session on the metal body, then:
- Primer,
- Giallo Modena,
- Rosso Corsa.
Also started to spray primer on the first 200 metal rivets.
400 left to do... before GM&RC.
Few of them will be White.
Voilà.
La suite bientôt!
Pascal
pgarat is offline   Reply With Quote
Old 03-17-2019, 03:55 PM   #18
pgarat
pgarat's Avatar
Hi,
Decals session
Once dry they are cleaned as well as the surrounding area.
Then holes are done in the decals.
More soon.
Pascal
Old 03-20-2019, 03:01 PM   #19
pgarat
pgarat's Avatar
Hi,
Just for fun:
DFV Cosworth piston and rod.
Voilà.
Pascal
Old 03-21-2019, 09:05 PM   #20
Stubeck
Looks great!
Stubeck is offline   Reply With Quote
Old 04-09-2019, 11:27 PM   #21
quadzero
quadzero's Avatar
What an adventure in model making. I truly enjoyed going through each picture with your amazing skill and attention to details. What a work of art.
quadzero is offline   Reply With Quote
Old 12-09-2019, 01:56 PM   #22
pgarat
pgarat's Avatar
Hi Mates,
The envy gradually returns...
Preparation of the front parts.
Difference between parts done and TBD.
Tanks temporarily installed:
A bit closer
Coils and ignition system done:
Exhaust Test fit:
Pascal*
Old 12-10-2019, 11:26 PM   #23
360spider
360spider's Avatar
Wow, another fantastic update! Your work is top notch.
ItalianHorses.net
360spider is offline   Reply With Quote
The Following User Says Thank You to 360spider For This Useful Post:
pgarat (12-11-2019)
Old 12-12-2019, 04:45 PM   #24
pgarat
pgarat's Avatar
Hi,
Thanks a lot for the kind comments.
Small progress ...
Preparation and installation of the hose and the serflexes on the pipes of the cooling system.
The tightening of the collar is simulated using aluminum foil and a piece of welding wire.
Same preparation for the 2 cooling scoops.
Test and alignment of the 1/2 rear axles and rods of the anti-roll bar.
Pascal
Old 12-14-2019, 06:14 AM   #25
pgarat
pgarat's Avatar
Hi,
Few progress and improvements.
I wanted to rebuild the anti roll bar with brass, but the original is good and almost hidden behind the tank...
The grills are installed on the radiator and the simulated inside tubing is still visible.
A new Sandow will replace the white metal part.
Pascal
Old 12-15-2019, 11:39 AM   #26
pgarat
pgarat's Avatar
Hi,
Still progression both on the rear and front.
Difference between before and after work on white metal parts.
The small bucket doesn’t belong to the 312F1...but to a Tipo 500.
I wanted to install thin aluminum sheet on the structure.
Pascal
Old 03-08-2020, 03:10 PM   #27
Lee Yoder
Lee Yoder's Avatar
WOW!!! I have not visited this forum in a couple of years, and when I do return, my jaw almost breaks as it hits the desk! Wonderful work and attention to detail. Chapeau!
Later,
Lee
Lee Yoder is offline   Reply With Quote
Old 03-08-2020, 04:13 PM   #28
quadzero
quadzero's Avatar
This is amazing. What a joy viewing the pictures.
Old 03-25-2020, 03:42 AM   #29
pgarat
pgarat's Avatar
Hi,
Thank you very much for comments Mates!
I finally managed to finish the ignition coils system, after a last modification.
Small brass bridges of 0.5 were installed on each side of the water / oil tank to hold the "bungee cord" in place after having stretched it.
There was a problem with the length of the radiator supports, I redid them in brass of 0.8 which I brazed with silver solder.
It was also time to paint the radiator(s): No more beautiful polished metal appearance and place for brass.
... And decided to represent the welded appearance of brass radiators.
Metalcote Alu, oils ...
A blank assembly of the various components of the rear axle and the exhausts to confirm that we are going in the right direction
It only remains to connect the lines to the master cylinder of the front brakes, this is done for the clutch and the rear.
Just have to finalize the assembly of the elements
I touched up the varnish and painted the underside of the hull.
Voili voilou.
More soon.
Pascal 8)
Old 03-28-2020, 08:33 AM   #30
pgarat
pgarat's Avatar
Hi
I decided to make the fuel cells connection faucet. It's made of white metal and a spare / modified distributor.
Working on the dashboard.
installed
the lower body part is now done and weathered
All the body parts are now fully dry. White dust is coming from the varnish dust while reopening the rivet holes.
The CAVALLINO is installed on the nose and the original decal is replaced by an "enamelled" badge from an old MFH reference.
Fit test of the front area.
Starting the riveting process...
Ainsi que sur les platines d'ancrage des tirants de suspension:
More soon!
Pascal
