Go Back   Automotive Forums .com Car Chat > Cars in General
Old 09-12-2017, 12:04 AM   #1
mechaniker
Tireject in cars
Hi
I know the maker says it is for ATVs, but if anyone tried it on a car, please tell us how it went.
Thanks
mechaniker is offline   Reply With Quote
Old 09-12-2017, 09:10 PM   #2
aleekat
Re: Tireject in cars
From their website:
TireJect will seal any tubeless rubber tire. For use in any highway speed vehicle we recommend that the tire is inspected by a certified tire shop to ensure it is safe to drive on. You can use TireJect for bead leaks or short term emergency road-side repair,
There is a safety risk with tires that are not properly inspected to ensure they are safe for highway speeds. For example, if the loss of air pressure is due to a punctured/damaged sidewall the tire runs high risk of failure which could be dangerous while operating at highway speeds.
This is why we recommend that the tire is inspected by a certified tire shop within 24 hours of application.
Additionally, you run the risk of damaging the TPMS sensors that are used in newer vehicles (>2008) especially if tire sealant is left inside the tire for more than 24 hours.
DO NOT apply more than 4oz per tire, doing so could cause tire balance and vibration issues at higher speeds.
Disclaimer:
We do not currently recommend long term use as a permanent repair in any vehicles operating at highway speeds. If you do use it is at your own risk.
Post back, that's what makes Forums Work.
aleekat is online now   Reply With Quote
The Following User Says Thank You to aleekat For This Useful Post:
mechaniker (09-12-2017)
Old 09-12-2017, 09:17 PM   #3
mechaniker
Thanks
Will it cause more tire imbalance and vibration for cars compared with slime and other sealants?
If not, then it is better because it seals larger holes.
Tags
tireject
