Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Talk
Old 10-07-2010, 06:10 AM   #1
2000GTMUSTANG
Mustang Questions
Hey Im new to this!
I have a 2000 Ford Mustang GT, Well I want to beef it up, well I want about 400-450HP or close to it. Now I no your all thinking that Im crazy lol cause I am lol everything is bone stock expect a K&N airtake!!
I need help and I ideas
-here a list In what Im planning to do
-Paxton Novi 2000 Superchargar kit in
-Long Tube polised SS headers
-Camshaft
-30 Fuel injectors
-Polised Tyhoon Intake
-Throttle Body Cable
-Preformance Intercooler systhem
-Programmer
-Full suspension
-And a Engine Tune-up
Things Im doining to the Rear
-T-LOCK
-Rear Gears- Not sure what size 3.73-4.10
If some stuff dont make no sence to you please correct me
Please leave your opion in what Brand I should go with.
Or what esle I could do to beef up my engine.
So of any one can help me that would be awsome
2000GTMUSTANG is offline   Reply With Quote
Old 10-07-2010, 07:48 AM   #2
JR Tigerstar
JR Tigerstar's Avatar
Re: Mustang Questions
Do you have a manual or automatic transmission?
p.s You will need camshafts.
JR Tigerstar is offline   Reply With Quote
Old 10-07-2010, 08:43 AM   #3
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
TwickFlow Twisted Wedge heads, stage 2 street/strip cams, Stainless Works long tube headers, a dyno tune should already get you close to 400HP (at the flywheel). If you want 400+RWHP, then get the Novi w/ intercooler.
You'll need a high flow fuel pump (Walbro 255 are good), and 30 lb/hr injectors...maybe higher. An 80 or 90mm MAF will also be necessary to flow enough air. And then a 75mm throttle body to get the air flow needed.
With a supercharger and that much power, I'd go with 3.55 or 3.73 gears since otherwise first gear will do nothing but roast tires.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 10-07-2010, 04:38 PM   #4
2000GTMUSTANG
Auto
Old 10-07-2010, 04:47 PM   #5
2000GTMUSTANG
Do you have a good site you can recomment to me?
Old 10-07-2010, 05:13 PM   #6
Blue)(Fusion
Since you have a 4R70W (auto) transmission, you can also do the J-mod for some tire-barking firm shifts at WOT.
Pretty much everything I listed above can be bought from Summit Racing or their respective manufacturer sites.
I had my tune done by Lonnie at Blue Oval Chips. He's the best in my opinion. You'll want a dyno tune from him to get maximum power. An email tune will be satisfactory before any blower is added for slightly improved power and a massively improved shift schedule.
J-mod you don't need parts except basic hand tools, a drill, some new Mercon V fluid, and new gaskets which can be found at your local dealer. Instructions are at TCCOA.
And for your choice of blowers, a roots type blower will provide more torque at lower RPMs and should not require an intercooler. If you go centrifugal, get a high stall torque converter, around 3500 RPM. With a roots, 2600 should be sufficient with the boosted low end torque.
Old 10-07-2010, 07:51 PM   #7
2000GTMUSTANG
I cant seem to find TwickFlow Twisted Wedge heads any were I've looked every were! can you give me a site you use? How much do they cost?
One another thing I have to ask been buging the shit out of me lol..If I decide not to go with a superchargar nor a Turbochargar
is posible ther any other way I can reach my goal! 400hp to the Rear wheels!
Sorry for my spelling!! Not the greatest spellers lol
Old 10-07-2010, 10:57 PM   #8
Blue)(Fusion
Twisted Flow 2v 4.6/5.4L heads @ Summit Racing
There are a few options and you will have to see what fits your needs/goals. Also note there are two combustion chamber size options in that list, 38cc and 44cc. Depending on the compression ratio you want. You'll want lower compression if you want to go blown or use nitrous to be safe.
And a much cheaper alternative to a supercharger is a nitrous kit. Zex kits are popular on the 4.6L 2v engines.
Old 10-08-2010, 08:15 PM   #9
2000GTMUSTANG
I have a question for you!
My friend drives a 2001 V6 Mustang bone stock he wants to put a 350RWHP
some one told him that the tranny will not hold that much horsepower is that true?
And much horsepower cana V6 engine take before boom lol can with, Same goes for the Transmission as well! Can he put that much Hp power to his stock Tranny and motor with out worrying! PLEASE HELP ME ANSWEAR HIS QUESTION THANKS
Old 10-08-2010, 09:26 PM   #10
Blue)(Fusion
I'm not sure what the V6 uses for a transmission. If it is the same 4-speed automatic 4R70W, it can handle about 400WHP.
Not sure what the V6 mod engines are capable of.
Old 10-09-2010, 01:05 AM   #11
2000GTMUSTANG
If he were to drop all this in His V6 auto
TwickFlow Twisted Wedge heads, stage 2 street/strip cams, Stainless Works long tube headers,Throttle Body Cable.Sensor.dyno tune,Fuel injectors,Polised Tyhoon Intake. Rear gears a Programmer
Know I dont know what V6 Auto mustang is capable of Hp and Tq..
He dosnt plan to race it on the Drag nothing like that.
should his stock transmission and motor take this with out no problems. with out no worries. I Red ever were like google saying the V6 Transmission and thing over 350-400Hp the transmission and rear end will go. But he dosnt plan to drop 400Hp under maybe 300-350Hp some were there! Thanks for yor help you guys been awsome
Old 10-09-2010, 10:37 AM   #12
Blue)(Fusion
AFAIK, there are no aftermarket heads for the V6 engines. There may be V6 headers, but I know Stainless Works does not make any. Cams, I don't know what's offered in that area, either.
Honestly, if he wants to improve power, get a V8. The torque increase alone will put a big smile on his face.
And like I said, I don't know what transmission the V6s used. If it is the 4R70W like in the V8s, then yes it will hold up. I've seen a few pushing 500WHP with only an aftermarket torque converter and a J-mod for their HP range.
Old 06-05-2015, 03:43 AM   #13
DanMustangit
7.5 Rear End Pinion Question
Hello, I hope this reaches somebody soon. I am working on my 2004 Mustang 3.9 and I am installing the pinion into the rear end, the front bearing is not sliding on easily and was wondering if somebody knew of a secret they could share. I am VERY mechanically inclined but have taken on a rear end for the first time.
Thanks
Dan
DanMustangit is offline   Reply With Quote
Old 10-30-2021, 05:27 PM   #14
daveshapellSVT
Specvgini
daveshapellSVT's Avatar
150 shot
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
daveshapellSVT is offline   Reply With Quote
94 GT mustang questions? GOFOR Mustang Talk 1 04-08-2004 01:40 PM
65 Mustang Question 90FZBronco Mustang Talk 2 03-15-2004 11:16 AM
99+ Mustang question chris26969 Mustang Talk 15 06-08-2003 04:37 PM
94 mustang question 76_cobra Mustang Talk 6 03-13-2003 08:41 AM
Just bought a '94 Mustang...questions. NeoFreek Mustang Talk 4 08-19-2002 03:54 PM
