| Latest | 0 Rplys |
04-27-2011, 05:33 PM | #16 | |
Re: Check Engine Light -- P0456
A small leak can turn into a large leak with time. With an evap leak your car can be polluting sitting in your garage as it is releasing hydrocarbons into the atmosphere.
06-07-2011, 05:22 PM | #17 | |
glade to hear its fix. Car Repair cost so much. I dont no how people do it. That why im here to help if you need any thing
Turn your Smartphone into a Bluetooth Scanner |
10-27-2011, 05:38 PM | #18 | |
Good afternoon – I have a check engine light on my 2003 town and country van – do you may know where can I take it for some to give me the code? do you know if Auto zone do it for free? Sorry to ask running a very low budget
10-27-2011, 06:04 PM | #19 | |
AF -Advisor
In most states Autozone will check your codes for free as will most other automotive parts stores. One exception is California. A state mandate says they can't check them at all. When you get the code come back here and post it in a new thread. Click "New Thread" at top left of the opening page of the Caravan forum.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
10-27-2011, 06:52 PM | #20 | |
I believe P0456 is a vacuum leak (major). I think a minor leak is P0445? Anyway, all you have to do is with the car off, turn the ignition switch off and on 3 times. The codes will come up in your odometer. Then you can go to google and google Dodge/Chrysler T&C codes and find out which one it is. My vacuum leak turned out to be a small 1/4 inch hose (90 degree elbow) on the sensing line from the gas tank (located on the driver side under the car). It was cracked on the top and didn't even show from the bottom, it had to be removed to find the crack. Now I have another check engine light, small vacuum leak, and am looking for it. What a pain they are.
10-27-2011, 08:17 PM | #21 | ||
AF -Advisor
"The codes will come up on your odometer". Works on 4th generation vans and some later 3rd gens. Otherwise count the SES light flashes.
11-04-2011, 03:03 PM | #22 | |
i have a 2002 T&C with the following codes: p1684, p0442, p0455, p0306, p0456. this seems very common on here and i need a lot of help narrowing these problems down. it seems like the 0442, 0455, and 0456 are some how connected. what are the most common causes of these codes. i've just found this forum and don't have time tonight to check what has already been suggested on here but am open to any more suggestions, i have to get these codes taken care of for inspection, thanks
11-04-2011, 04:33 PM | #23 |
AF -Advisor
